Digital Art Zone
Problem with Taylor Hair
Posted: 19 July 2012 09:42 PM   [ Ignore ]
New Member
Avatar
Joined  2003-10-09
I’m having a problem with the new Taylor hair.  It’s a figure (CR2) and when I load it and conform it to M4 and apply the M4 fitting morph, it doesn’t move into the proper place.  The picture below shows the base and where it ends up in relation to M4.  Has anyone else had success with using this hair with M4?
Image Attachments
Profile
Posted: 20 July 2012 10:41 AM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2010-02-14
Is the hair itself even “Fitted” to M4? Check that first.
 Signature
“I’m sorry, I can’t hear you over the sound of how awesome I am!” ~ Brextor Ultimus
FORUM MEMBER POST RANKS
New Member = 0
Member = 25
Active Member = 250
Power Member = 1000
Addict = 2500
Profile
Posted: 22 July 2012 02:21 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2011-10-02
I got it to work fine with a little trial and error.  First, you have to use the Poser library hair (not Genesis).  Although the hair morphs actually have a “fit M4” dial, ignore that.  Then select the hair in the scene, go to pose and select the fit cap..  The hair disappeared and the cap appeared half stuck into his head.  Then I went back to the parameter and dialed up the “fit M4”.  With the cap it’s easy to see when it fits his skull and it fit perfectly, but took a bit of dialing.  Pick a colour and suddenly you have hair that fits.  I tried it with and without his default hair and it worked great.  Hope that helps anyone else having the same problem.
Profile
Posted: 22 July 2012 10:43 AM   [ Ignore ]   [ # 3 ]
Active Member
RankRank
Joined  2010-02-14
I see. Yeah, when you buy Gen 4 hair, ALWAYS look for the “FitTo” dials.
Well, either way, glad to hear you got it worked out. smile
 Signature
New Member = 0
Member = 25
Active Member = 250
Power Member = 1000
Addict = 2500
Profile
Posted: 22 July 2012 11:30 AM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2011-10-02
There wasn’t anything really intuitive about that fit, but, well worth any effort for unisex hair that fits Gen 4 and Genesis!
Profile
