Digital Art Zone
1 of 2
1
Animate Carrara water preset?
Posted: 19 July 2012 04:22 PM   [ Ignore ]
Member
Avatar
Rank
Joined  0
Hello-
Can the water presets that come with Carrara be animated?
And if so, which settings does one adjust?
I tried shuffling the fractal settings, and that may do it, but the settings themselves don’t seem to change.
Any water experts here? wink
Thanks for looking.
Profile
Posted: 19 July 2012 04:50 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2005-10-11
Hi Bagboy,
I think you can animate any of the shader parameters…...but if you want realistic water,
did you try adding an Ocean?  It’s one of the icons at the top…...what version of Carrara are
you using?
 Signature
My YouTube channel
www.blenderportal.com
Profile
Posted: 19 July 2012 05:06 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2011-01-03
megacal - 19 July 2012 04:50 PM
Hi Bagboy,
you using?
If I recall off the top of my head, the Ocean Primitive is only in Carrara Pro.
I have not done any serious animation in Carrara (yet); but I do want to make animating water one of the first things that I try.
 Signature
- Garstor
Australian-Canadian currently trapped in Texas (maintaining sanity with doses of Carrara, LightWave and PhotoShop)
My 3D art Flickr page for final or near-final images
My 3D art Flickr page for work-in-progress or experiments
Profile
Posted: 19 July 2012 05:19 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  0
Hi Bagboy,
you using?
Hi Megacal, and thanks for the tip.-
I’m using Carrrara Pro 8.1.1.12.
I’ll take a look at the ocean primitive if need be. That may indeed be the way to go.
I’d dug out a “canal” out of my own model, added a surface for the water that fit into the canal, and applied a preset turbulent muddy water shader to it.  I’d like to have it appear to move at least a little so it doesn’t look frozen. :D
It would seem to me that one could jiggle the fractal setting to add some movement, but I wasn’t sure what to adjust.
Maybe if I just shifted the center in the Transform panel of the Fractal Noise settings it would be enough.
Thanks again.
Profile
Posted: 19 July 2012 05:35 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2011-01-03
Bagboy - 19 July 2012 05:19 PM
The Ocean primitive does have a “waves follow the wind” and a direction setting. I believe that cripeman has a YouTube tutorial where he animated Ocean using a post card image of Chicago…the Ocean became Lake Michigan moving past the city line. I’d bet there is enough info there to get you started.
 Signature
- Garstor
Profile
Posted: 19 July 2012 05:39 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  0
Garstor - 19 July 2012 05:35 PM
Thanks Garstor!
Hooray for Cripeman! Yeah, I love his tutorials. He’s a treasure!
I’ll have to look it up.
Profile
Posted: 19 July 2012 06:40 PM   [ Ignore ]   [ # 6 ]
Active Member
RankRank
Joined  2007-10-15
Also, FWIW, I’d strongly recommend that if anyone is animating any type of water that you consider that in the vast majority of cases, waves are generated by wind, and are going on one direction. As has already been mentioned, the ocean primitive has a setting for that.
Far too often you see animated water that has nice looking waves, but they’re bouncing around randomly and it looks very unnatural. I don’t recall how the results of the animated ocean with wave direction actually appear, but I’d suggest you make sure your results look natural and fairly unidirectional.
As always, reference videos are quick and easy to find, and can help a lot with proper relative wave sizes and stuff like that.
Profile
Posted: 19 July 2012 07:20 PM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  0
JoeMamma2000 - 19 July 2012 06:40 PM
Great analysis and advice, JoeM.
I didn’t really dig too deeply into waves, so your points are well taken.
I’m testing moving the fractals around, in one direction as it turns out, so maybe this will work out okay all around.
I also should mention that I don’t need too much detail, I don’t think, so if I can get satisfactory results from the shaders , they will serve my purpose.
But, you’ve given me food for thought.
Profile
Posted: 19 July 2012 07:25 PM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2005-10-11
Here’s one I did a while back…....just an ebb & flow. smile
(can’t use the script for some reason…..have to copy/paste the url)
http://www.youtube.com/watch?v=uZBKSkHdnR0
 Signature
My YouTube channel
Profile
Posted: 19 July 2012 07:28 PM   [ Ignore ]   [ # 9 ]
Member
Avatar
Rank
Joined  0
BTW, Cripeman’s tutorial on the Ocean Waves was informative as usual.
And the waves he showed looked pretty good.
Profile
Posted: 19 July 2012 10:18 PM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
hi you can also use the terrain shader to simulate white water
from memory you can also stack modifiers eg wave modifier and noise modifier
and you can animate the bump channel, also use avi for your texture to moved bump across the water
you can also use avi in th e displacement channel to mimic wave movement
 Signature
http://andrewfinnie.blogspot.com.au/
Profile
Posted: 20 July 2012 02:43 AM   [ Ignore ]   [ # 11 ]
Member
Avatar
Rank
Joined  2005-10-11
Great suggestions,  head wax. smile
 Signature
My YouTube channel
Profile
Posted: 20 July 2012 02:50 AM   [ Ignore ]   [ # 12 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
I animate the wave or ripples shader natural function in bump or displacement, it has completion, perpetration etc that can be oscillated for continual movement and centre H and V that can be translated for directional movement.
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 20 July 2012 03:53 AM   [ Ignore ]   [ # 13 ]
Active Member
RankRank
Joined  2010-11-30
You might want to consider getting the Brianorca Ocean Plugin for Carrara.  It isn’t that expensive.
http://www.brianorca.com/CarraraPluginOcean.html
Profile
Posted: 20 July 2012 07:07 PM   [ Ignore ]   [ # 14 ]
Member
Avatar
Rank
Joined  0
megacal - 19 July 2012 07:25 PM
Very nice!
Profile
Posted: 20 July 2012 07:11 PM   [ Ignore ]   [ # 15 ]
Member
Avatar
Rank
Joined  0
wendy♥catz - 20 July 2012 02:50 AM
Thanks Wendyluvscats!
I was trying this out and looks promising.
Can the wave loop? Completion goes from 0 to 100 for the waves, but I’m not clear on if that means one cycle, or what.
Profile
1 of 2
1
