Image on a Plane
Posted: 19 July 2012 12:35 PM
[ Ignore ]
Member
Joined 2010-02-05
I’m not able to display an image on a plane primitive. I’m trying to add it throug hthe Srufaces tab in the Diffuse Color section, it appears there, but not on the actual plane, Do any others settings have to be adjusted?
Posted: 19 July 2012 12:46 PM
[ Ignore ]
[ # 1 ]
Administrator
Joined 2009-01-22
Is your Diffuse Strenght set to 100%? I can get an image easily. Also you will need a light on the Front of the plane for the image to show. If your lighting is behind it the image will not be visable.
Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Posted: 19 July 2012 01:02 PM
[ Ignore ]
[ # 2 ]
Member
Joined 2010-02-05
If the sizes are off, is there a way to stretch or shrink the image to fit?
Posted: 19 July 2012 01:09 PM
[ Ignore ]
[ # 3 ]
Administrator
Joined 2009-01-22
Just shrink your Plane with the Prameters Tab, X and Z scale I belive.
P.S. Square images are the best to work with. But a 2D art program is handy for editing your Image file.
Signature
Posted: 19 July 2012 01:13 PM
[ Ignore ]
[ # 4 ]
Member
Joined 2010-02-05
I still got nothing. I tried jpg, png, bmp, all different sizes, added lights, rotated and resized the plane and it’s still gray.
Posted: 19 July 2012 01:17 PM
[ Ignore ]
[ # 5 ]
Administrator
Joined 2009-01-22
How are you doing this? Create Primative Plane. Select Plane in Scene Tab. Open Surfaces Tab. Open Default Diffuse, use Drop down arrow to browse to image. Add Image. My steps.
I’m in DS4Pro what are you using.
EDIT: Diffuse Color to add the image.
Signature
Posted: 19 July 2012 01:20 PM
[ Ignore ]
[ # 6 ]
Member
Joined 2010-02-05
Yes, I did everything you did. I have 4.0 pro 64bit. I just tried rendering and it DOES show, but for some reason not in Studio… is that normal?
Posted: 19 July 2012 01:28 PM
[ Ignore ]
[ # 7 ]
Administrator
Joined 2009-01-22
That might be a issue of your Graphic Card. But I’m not sure. Do you get textures on other Items like Genesis?
Signature
Posted: 19 July 2012 01:36 PM
[ Ignore ]
[ # 8 ]
Member
Joined 2010-02-05
All other textures seem to work fine. As long as it renders fine I guess it’s OK. Thanks for the suggestions.
FYI: I have an HP laptop with an Intel Graphics Media Accelerator 4500MHD w/ 2 MB of video memory.
Posted: 19 July 2012 01:59 PM
[ Ignore ]
[ # 9 ]
Administrator
Joined 2009-01-22
Okay, But I’m still puzzled.
Signature
Active Member
Joined 2011-05-02
I know it might be obvious, I am new with Daz Studio, you have to have the draw style set to texture shaded, I have made that mistake.
Member
Joined 2010-02-05
You win the prize! Somehow I had it set to smooth shaded!
Active Member
Joined 2011-05-02
Ha,, It was no “surprize”, n I like prizes
Administrator
Joined 2009-01-22
Well I’ll be, never crossed my febble mind to ask about the draw style. DUH!
Signature
