Hair following elf ear morph!
KharmaKharma Posts: 2,420
Sorry as I know this has been asked but after numerous searches I couldn't find it. How do I stop hair from sticking out around elf ears? I am sure it had to do with autofollow but I cannot find it .
  • Richard HaseltineRichard Haseltine Posts: 41,203
    A temporary fix is to enable the display of hidden parameters (click on the lined button at top-right of the Parameters pane, or right-click on the pane's tab, to get a menu including that option) and then zero the generated morph. A more permanent fix is to create a new property in the hair with the exact name of the morph you want to block, so that DS won't attempt to generate its own morph.
  • KharmaKharma Posts: 2,420
    ok thanks Richard I will try that
