Digital Art Zone
Bryce 7 pro terrible rendering…..
Posted: 19 July 2012 12:05 AM   [ Ignore ]
New Member
Joined  2012-07-13
Hey guys Aim confused about rendered selection. I started Bruce 7 and without changing any of the defaults i added terrain from the top tool bar. I did nothing but erode the mountain terrain little and hit the render button. Took 35 seconds or so to render but looks terrible!!! Looks like water color paint job. So i then in render options changed the resolution to a higher setting and it took 4 times longer to render but….. looks worst than the lower setting???  I have a pc with windows7 ultimate 64bit…8.gb ram…Intel duo 2 4 core cup… with a nvidia 9800.GT card. I thought i was better than system requirements but now no so sure? My question is…. is there a optimal setting and or setup that i should to get the results i see everyone else getting?? Or do i need to get a better card??? Thanks
Profile
Posted: 19 July 2012 03:27 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
If you post an image of your result it would be easier to work out what your problems are.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 19 July 2012 03:52 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
Could you show a screenshot of your render settings?
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 19 July 2012 07:55 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2012-07-13
Hey guys, Thanks for the help. Iam not sure what you want??
Image Attachments
Profile
Posted: 20 July 2012 12:03 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
Your last picture: you have Preview render checked instead of Full render in the second column on top under “General”.
 Signature
Profile
Posted: 20 July 2012 03:52 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
You also have DOF checked and at quite a high amount. DOF is best used very carefully to avoid pixelation. How did you determine your Focal length ?
The ideal way to use DOF is to select the mesh on your preview window that you want to be in focu, and then on your premium render screen select “Set to current selection”
When I use DOF I find I mostly set it between 0.01 and 0.05. I actually tend to drive DOF with a combo of the actual DOF setting and haze in the sky lab.
 Signature
Profile
Posted: 22 July 2012 02:41 PM   [ Ignore ]   [ # 6 ]
New Member
Joined  2012-07-13
Thanks guys for the responce. Like I said I have not messed with any settings except changing to premium in quality mode. This is Bryce 7 unaltered. I have no idea how or what to change? I thought this default starting point was middle of the road to have desent perspective of what to do . Was hoping there was an optimal setting page to get the best setup that your pc would allow. I am totally new to this and how every intention of mastering it,,,But! was hoping for a steer in the right direction. I finally found some bryce tutorials that Iam starting to watch but PLEASE any advice would be very welcome! Thanks and God Bless!!
Profile
Posted: 22 July 2012 04:07 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Well today I have been having ISP problems all day, with intermittent internet access, and more down than up. Hopefully tomorrow it will be sorted, and I can post a few screen shots for you to help you along the way.
Bryce is fun, once you get started.
 Signature
Profile
Posted: 22 July 2012 05:00 PM   [ Ignore ]   [ # 8 ]
New Member
Joined  2004-09-23
Try these render settings.
  I think most of your problem is the the material that Bryce will randomly pick for you or if you selected it yourself, then the way it is default mapping it to your terrain.
  The middle image is “grassy peaks”.  Looks sick like yours.
  The bottom image is the same terrain lowered a bit with, a different included material applied and the sun move to the horizon to the right.  A completely different ball game, huh?  Bryce is amazing.
  Take heart, I don’t think your Bryce is broken.
Image Attachments
Profile
