Earlier I could create animation with DAZ but after I did a upgrade on my computer of full version of WIN 7 64 bit on new formated hard disks, I can’t create video file anymore!
The render works as it should but then DAZ is going to create the avi. file the error come!
A small windows comes up and a message is Unable use “Compression Settings”!
The only thing I can select in the small window is for Compressor is Microsoft RLE!
Then I try that folowing message comes up!
“The compression type you selected could not be initialized. Please select another compressor type!
I can’t select another cause the only one that exist is the one mention above!
Yesterday I noticed something else and I don’t know if this is the “bug” that cause the error!
Then I load up DAZ and the first window that come up show 2 things that I need to put reg key
to use those plugs in! I noticed that one of them are “animate2”
The same that is used under Pose and Animate then I working in DAZ!
I tried to put in the reg key as for DAZ there to see if that kill the “bug” but it was wrong key!
Later I found out that animate2 cost about 50-60 US Dollar on the DAZ shop!
I don’t understand a thing of this! How can animate2 be in my DAZ Studio Pro if I can’t use
it?
Thanks!
