Digital Art Zone
Daz Studio morphs with Sculptris?
Posted: 24 May 2012 08:12 PM   [ Ignore ]
Member
Rank
Joined  2012-05-24
Hi, let me apologize in advance because I know there is already a tutorial on this somewhere; I found a link to it via google. But that link seems to be broken and I can’t find that thread with the forum search either.
I’d like to know how to create morphs in Sculptris and import them into Daz Studio, then rig them. I intend to use my own morphs as posable “dolls” for a series of artworks, because the meshes I would need would have features that Genesis models don’t offer (horns, wings, tails, absence of hands and feet, etc). If anyone can point me to the tutorial I’m referring to, that would be great; any other advice would be welcome also. I should probably mention that I’m very new to 3d art. Thank you!
Profile
Posted: 24 May 2012 08:47 PM   [ Ignore ]   [ # 1 ]
New Member
Joined  2012-02-08
I’m trying to do what you are doing, except with complex complete body morphs…It’s going to take a long time for me, but you’ll find it easy enough with Sculptris.  Anyways, I found a video on youtube which outlines how to make morphs in zbrush (here: http://www.youtube.com/watch?feature=player_embedded&v=BI-a9XiXBNM).  I would follow the same general steps, except not export to zbrush and follow the steps outlined below:
1) export Genesis as an OBJ.
2) import that OBJ into Sculptris
3) do what you need in Sculptris
4) export the finished model in Sculptris as an OBJ
5) use the morph loader advanced/pro to import the OBJ as a morph
6) follow the rest of the video!
Profile
Posted: 24 May 2012 09:14 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2012-05-24
Thanks for replying! I can’t find a Morph Loader Pro/Advanced. Is that the same thing as Morph Master Pro? That one is Windows only… :(
Profile
Posted: 24 May 2012 09:25 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2012-02-08
I do not know…  Is it in the top menu’s Edit->Object or Edit->Figure?  If it is, Morph Master Pro should be it.
Profile
Posted: 24 May 2012 11:21 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
If you got the free Pro version Morph Loader Pro and Advanced are included so they BOTH should be there.  The icons both look like an arm bent with a bulging bicep.  I use Advanced over Pro, Like it better!
I’m curious about what import setting one would use for Sculptris?  I used the Cinema 4D import for ZBrush and that works well but never thought about using Sculptris for making body shapes for Genesis!  Hmmmmm
 Signature
—-Wolff On The Prowl—-
Posts: 28,985 and counting!
        RAMWolffsWorld
Profile
Posted: 25 May 2012 08:41 AM   [ Ignore ]   [ # 5 ]
New Member
Joined  2012-02-08
I’d just use the defaults…  Try what you need until you get the correct result!
Profile
Posted: 26 May 2012 03:38 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2012-05-24
I found it, thanks a lot!
I also heard that in order to use Sculptris for Daz Studio morphs, you have to set the detail to 0. Is that true?
Profile
Posted: 22 June 2012 06:21 AM   [ Ignore ]   [ # 7 ]
New Member
Joined  0
Yes its true, cause Sculptris will add Vertices if you don’t set detail to zero and then the resulting OBJ will have a different vertex-count.
Profile
Posted: 22 September 2012 05:30 AM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
two dumb questions
first, I cannot get Genesis into Sculptris,
(it says something about multiple triangle connections)
second, where is undo in Sculptris?
I have perused the manual, tried all the tools and rightclicks etc
undo is essential to me and not finding it is pretty much the reason I have not used it much.
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 22 September 2012 07:39 AM   [ Ignore ]   [ # 9 ]
New Member
Joined  2012-01-28
wendy♥catz - 22 September 2012 05:30 AM
two dumb questions
What I do is press Ctr Z whenever I want to undo something in Sculptris. It works for most programs on the market.
Profile
Posted: 22 September 2012 07:52 AM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
thx, I never remember those keyboard shortcuts
t, the copy/paste one is another I always forget and some programs will not let you use rightclick paste for serials
Carrara drives me nuts there! and I accidently do stuff with shortcuts like 0 to frame a selected figure! (when I was meaning to type zero somewhere!)
 Signature
Profile
Posted: 22 September 2012 08:18 AM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Yea, Ctrl Z is your best friend allot of the times when testing stuff.
 Signature
        RAMWolffsWorld
Profile
Posted: 25 September 2012 06:05 PM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2005-07-29
You can find a basic tutorial on making morphs in my sig that may be helpful but I have never used Sculptris before.
I used to use Hexagon but splurged and got ZBrush recently so… WHEEEEEE!
That’s me… repeatedly sliding down the learning curve. smile
Would you be so kind as to post some info regarding what you may have found when trying to make morphs with Sculptris?
I would be interested in learning more about it.
 Signature
<End of transmission from Oz>
TUTORIAL - Creating a Genesis Full Body Morph for DAZ Studio Pro 4 by RKane_1
TUTORIAL - Creating a Genesis Partial Body Morph in DAZ Studio Pro 4 Using the DForm Tool by RKane_1
TUTORIAL - Applying Shaders by RKane_1 (as stolen blatantly from Jaderail)
Profile
Posted: 25 September 2012 07:47 PM   [ Ignore ]   [ # 13 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Love Sculptris but it really needs to be more mature before I venture back into it.  ZBrush is enough for now!  lol
 Signature
        RAMWolffsWorld
Profile
Posted: 25 September 2012 08:27 PM   [ Ignore ]   [ # 14 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
RAMWolff - 25 September 2012 07:47 PM
I don’t think that’s ever going to happen…they’ve been at the same version for going on two or three years now.  Plus it is owned by the same company as Zbrush.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 25 September 2012 11:44 PM   [ Ignore ]   [ # 15 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Well aware of that but there are a few more tools they could add to it to make it a tiny bit more useful, like a way to convert triangles to regular old fashioned vertices that allot of programs still prefer.  I like Sculptris allot, it’s allot of fun to play around in but for anything being really useful in making content… nope, not yet…. I imagine in another 3 to 5 years they might get around to it!  raspberry
 Signature
        RAMWolffsWorld
Profile
