Digital Art Zone
1 of 2
1
Daz 4.5 and Dynamics?
Posted: 16 July 2012 06:08 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2005-02-25
Does Daz 4.5 have dynamics?  I can’t find a tab for dynamics under windows.
It has my working serial code for dynamics clothing control and says that it’s been loaded properly but its’ not there that I can see.
Profile
Posted: 16 July 2012 06:31 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2004-11-07
Studio dynamics only works with studio dynamic cloths, it’s not poser.
http://www.optitex-dynamiccloth.com/FreebieDownload01.php
http://www.daz3d.com/shop/catalogsearch/result/?q=dynamic&x=0&y=0
You also have to go to the set up to have the menu for the dynamic clothes. that would be at the top left window/tabs.
 Signature
Profile
Posted: 16 July 2012 06:58 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
ManStan, I’m aware that it only works with optitex dynamic clothing, which I have installed, along with dynamic clothing control plugin.  I went to the windows/tabs, and there IS NOT a dynamic clothing tab option.  I looked.  As I said in my first pot, I can’t find it. :(
Profile
Posted: 16 July 2012 07:08 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Check your Help > About Installed Plugins to make sure that it loaded correctly.
 Signature
My Tutorials and Freebies Index
Profile
Posted: 16 July 2012 07:29 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
Adamr001, it has the dynamics clothing control installed. I don’ see anything else. It was my understanding that DS4 comes with dynamics installed and i just needed to ad the control, correct?
Profile
Posted: 16 July 2012 07:54 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2004-09-07
An admin may correct me if I’m wrong - but I thought that D/S 4.5 was in Beta and plugins DID NOT yet work in it? That may be why you can’t find it in there even though it says it’s installed.
This is the reason I rolled back to 4.0 - there are some plugins I need ... again, I may be wrong, but I thought that was the case with 4.5?
 Signature
Mercedes Keyes
Amber Swann Publishing Inc.
Facebook
Published Novels
DeviantArt
3D Graphics Art Community - Google+ Join me there
Profile
Posted: 16 July 2012 08:08 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2004-11-07
I’m running studio 4.5, my dynamics menu is right where it should be, it’s also listed in the tabs menu. So not at all sure why you don’t have it.
Sorry, unless stated other wise I assume questions like this are from poser users that aren’t familiar with studio dynamics.
Of coarse my version of studio is still loading to my windows tool bar, and not actually opening. I have to open it from the windows tool bar.
But I’m not doing anything with studio till they finally; if ever, get DUF working.
 Signature
Profile
Posted: 16 July 2012 08:48 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
belovedalia - 16 July 2012 07:29 AM
Is the plugin green?  If so, then you may simply need to reset your layout.  There’s an (infrequent) bug that causes menu items to not show correctly on some layouts.  Changing back to the default and then back to your custom layout should restore the menu.
Below is more or less what a good plugin (and a bad one) should look like.
Image Attachments
 Signature
Profile
Posted: 16 July 2012 11:24 AM   [ Ignore ]   [ # 8 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
Be sure that you have the most recent version of the control plug in. If not it will nurf the dynamics all around.
Profile
Posted: 16 July 2012 02:33 PM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
adamr001 - 16 July 2012 08:48 AM
It is green, yes.  I tried that with the layout as you suggested, but no luck.
Tomorrow I will redownload the dynamic clothing plugin and try again.
Bummer, I really need this to work- its holding up an art commission I’m working on.
Profile
Posted: 16 July 2012 05:48 PM   [ Ignore ]   [ # 10 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Don’t redownload—the only Dynamic Control plugin that works with 4.5 is the one i n the zip file with 4.5.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 16 July 2012 06:40 PM   [ Ignore ]   [ # 11 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
That is not the control plug in. That is the basic dynamics that everyone gets. Unless they made a change and have included the additional plug in with 4.5. Can’t imagine they wouldn’t have mentioned that though.
I think that the control plugin version should be 1.0.11.19 or higher.
Profile
Posted: 16 July 2012 06:48 PM   [ Ignore ]   [ # 12 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
No, they included an installer for the control plugin in the 4.5 download, but you still need a valid serial number to activate it,  1.0.11.19 won’t work with DS 4.5, the last number needs to be 49 or higher.
 Signature
Products In Zips
Profile
Posted: 16 July 2012 08:38 PM   [ Ignore ]   [ # 13 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
So now the pay for plug ins are included in the installs? How many others did they include? And what possessed them to start bloating the files with pay for products?
Profile
Posted: 16 July 2012 08:49 PM   [ Ignore ]   [ # 14 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
They included it because it’s a DAZ-owned plugin which had been updated for the RC.  Once 4.5 is officially released it’ll go back to normal.
 Signature
Products In Zips
Profile
Posted: 16 July 2012 09:16 PM   [ Ignore ]   [ # 15 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
I would guess then that the have fixed the error that having it installed without a proper SN use cause. If it wasn’t activated properly it totally wrecked using dynamics at all.
Profile
1 of 2
1
