Hyper Threading AMD?
3dcal3dcal Posts: 169
Should an AMD PHenom II X4 955 be able to hyper thread in Carrara 8Pro?
Am only getting 4 tiles. =(
When selecting a CPU, how can you know ahead if it is capable of hyper-threading?
  • wavyeyewavyeye Posts: 18
    AMDs don't do / require hyperthreading, you get four real cores in a X4.
    Hyperthreading is an intel feature.
    If you have good motherboard you should be able to overclock your chip though.
    I'm running a FX 8 core and have it comfortably clocked from 3.6 to 4.2ghz.
    I used to run my Phenom X4 3.2 at around 3.8ghz.
  • 3dcal3dcal Posts: 169
    edited July 2012
    AMDs don’t do / require hyperthreading
    Ok, well that 'splains it! I built the computer last year
    as an Octane Render box to use CUDA cards.
    Just put Carrara on it yesterday, and realized it wasn't hyperthreading.
    Thanks for the info. ;)
    Post edited by 3dcal on
    The main board is an ASUS M4A89GTD Pro ( =O ) and says I can over-clock it, boost it, and hit
    the Turbo key, so will see how fast I can get it to go, though I doubt it would come close to
    Garstor's new smokin' screamer. :cheese:
