3dView - 15 July 2012 04:27 AM
Garstor—-
Wow—-sounds like a great machine——-if you could you post the specs ie. ram (company/ type) Mobo etc—-I am sure others might be interested as well. Always wondered about those opterons with all those cores. Its so helpful to have specs of a working machine to copy when making a new rig or buying components.
SPECS - msinfo32.exe
OS Name Microsoft Windows Server 2008 R2 Enterprise
Version 6.1.7601 Service Pack 1 Build 7601
System Manufacturer ASUSTeK Computer INC.
System Model KGP(M)E-D16
System Type x64-based PC
Processor AMD Opteron(TM) Processor 6238, 2600 Mhz, 6 Core(s), 12 Logical Processor(s)
Total Physical Memory 64.0 GB
PARTS
ASUS KGPE-D16 SSI EEB 3.61 Server Motherboard Dual Socket G34 AMD SR5690 DDR3 1600/1333/1066/800
AMD Opteron 6238 Interlagos 2.6GHz 16MB L3 Cache Socket G34 115W 12-Core Server Processor (x2)
ASUS ENGTX550 Ti/DI/1GD5 GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16
* not a bleeding edge video card because the primary purpose of the machine is to run virtual servers - but I did need something beefier than an on-board video card
Western Digitial Caviar Black 1TB SATA-3 hard drives (x5)
Athena Power CA-SWH01B90 Black Steel Pedestal Server Case
* this was the only case I could find to fit the over-sized motherboard - only caveat here is that it comes with a single fan, so I may need to add more in the future
* also, I am not sure about blaming the case or the video card, but the when the card is seated in the mobo, it is still too tall to be secured to the case with screws
BE AWARE: I am still investigating this and it is probably AMD’s chip design fault…but I noticed in PerfMon that occasionally the total CPU processing would drop to near zero. It quickly shot back up to over 80% but would eventually repeat this. I suspect that this is caused by the on-chip L1 cache becoming invalid and needing to be flushed. Certainly a major performance if you are doing genetic research into cancer or something…but probably not serious for Carrara - just annoying for an uber-geek.
Honestly; I would have preferred buying Intel but I wanted tons of cores and the price couldn’t be beat. I was feeling better about the purchased when I learned that 3DAGE has used Carrara exclusively on AMD chips.
But for long-term, “real” server-grade work, Intel is probably the way to go.
