Digital Art Zone
Opening Help File (Carrara 6 Pro)
Posted: 14 July 2012 05:12 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2003-10-09
I have the latest Adobe acrobat pdf reader installed, but when I try to open the Carrara help file it keeps telling me I need to install Adobe acrobat reader
How would I fix this?
Thanks
I’ve been a member of this forum for years, but apparently this is my “first post” since the original forum has been trashed tongue rolleye
 Signature
Nate Owens illustrator/painter | publications | greeting cards
Portfolio: http://www.thecreativefinder.com/nateowens | illustration: http://www.artpixelstudios.com | Paintings: http://www.nateowens.com
Profile
Posted: 14 July 2012 05:51 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2006-09-30
Try the free foxit pdf reader.
No need for adobe stuff.
Ever!
 Signature
MOO!
Profile
Posted: 14 July 2012 06:31 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2003-10-09
Adobe reader works for everything else, all websites.
Carrara is special, requires special custom software?
Image Attachments
 Signature
Profile
Posted: 14 July 2012 06:42 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2006-09-30
Nah.
It’s just a test to see if the file is corrupt.
And I can never resist a chance to poke fun at adobe!  Personal reasons.
 Signature
MOO!
Profile
Posted: 14 July 2012 07:23 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2003-10-09
Ah-hah!
I can open the file if I go to the Carrara folder in my program files and select the file there, opens ok with (adobe) reader.
I can’t open it from inside Carrara by clicking on the help tab - trying to get a fix on that.
(I use Photoshop and illustrator often… just raggin’ on ya) wink
 Signature
Profile
Posted: 14 July 2012 08:13 AM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI Nate
This sounds like a file association issue in Windows,
Carrara opens the Help in Adobe Acrobat pro for me, ...no issues, and you shouldn’t have any issues in opening this help file if you have either the full version of Acrobat, or the free Acrobat reader installed.
Does Acrobat open the help manual if you double click on the PDF,.? ... or do you need to go to “Open with”
Also, is the icon displayed for the manual the correct one for a PDF. ?
Downloading and installing the free acrobat reader may be the quickest, and simplest way to correct the file association.
running a registry editor should also work.
Hope it helps smile
Image Attachments
Profile
