Digital Art Zone
Hair Thru The Hat
Posted: 12 July 2012 11:54 PM   [ Ignore ]
Member
Rank
Joined  0
As this render shows M4 hair is sticking through his hat. How do I keep this from happening? I’m working on a Mac Pro 8 core in OSX 10.6.8 with Daz4 4.0.3.47. Any help?
Image Attachments
Profile
Posted: 13 July 2012 12:09 AM   [ Ignore ]   [ # 1 ]
Power Member
RankRankRank
Joined  2007-06-22
I usually use Dforms, and a bit of post work to cover any little bits that are left.
Profile
Posted: 13 July 2012 05:24 AM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
You can also render just the hat, then layer that over the full render and erase it as needed to only mask out the unwanted hair. Lyrra has a set of magnets to help with fitting hair under hats.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 13 July 2012 05:28 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Add to above it also depends on what the material zones are like as I have had some sucess in taking out the trans maps for certian zones and use 0% Opacity making certain parts of the hair invisible
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 13 July 2012 05:45 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Richard mentioned Lyrra’s magnet / deformer set. It can be found here http://www.daz3d.com/shop/deformers-plus-hat-head/
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 13 July 2012 06:21 AM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
You can also use the “Polygon Group Editor” tool to select the hair polys that are poking thru and make them invisible.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 13 July 2012 07:42 AM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Kendall Sears - 13 July 2012 06:21 AM
Kendall
Oh yeah I use that and never thought of doing that for hair Kendall. I am going now before I look more stupid….what you say too late. LOL
 Signature
Pete
My Render Thread
Profile
Posted: 13 July 2012 07:49 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Kendall
I need to make a note here.  If using the PGE and you need to save the results, don’t use “Polygon Visibility -> Hide Selected” as this will not be retained across DS4 sessions.  If you need the “hides” to be persistent then use “Polygon Assignment -> Create Surface from Selected…”  to create a new Material Group.  Then you can assign all of the other polys to this same group.  From the surfaces tab, set the Opacity to 0% and you’ve now permanently set those polys invisible for that scene.
Kendall
 Signature
Profile
Posted: 14 July 2012 06:55 PM   [ Ignore ]   [ # 8 ]
Power Member
Avatar
RankRankRank
Joined  2010-12-18
Kendall Sears - 13 July 2012 07:49 AM
Kendall
Kendall
Thanks so much for this, I just happened to need this today and it works like a charm. I actually never used the PGE until today but I was able to find it in the menu and follow your steps quickly.
Thanks again.
Profile
