Digital Art Zone
World Travels strangeness
Posted: 11 July 2012 09:23 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2012-02-04
So I purchased the World Travels horse carriage to try to get an idea out of my head.
But when I render it, strange things happen.
The doors have developed a white film.
The side panels are bright and the undercarriage is hideous metallic.
Please not I have not changed anything or mucked about with the surfaces at all.
I have also tried a fresh install of World Travels, but nothing changed.
Any ideas what happened here?
Is there any way to fix this mess?
Thanks for any and all advice.
Image Attachments
 Signature
“Art is unique and individual and exists beyond the realms inhabited by those who would reduce things to mere measuring.”  ~Cave
http://ippotamus.deviantart.com/
Profile
Posted: 11 July 2012 10:03 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
There’s a reflection channel on those areas, which may be having a different effect in DAZ Studio than it does in Poser.  As a test, go to the Surfaces tab, select all surfaces, and set Reflection strength to 0, and see if that looks better.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 11 July 2012 11:13 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
Given that leaf springs and axles are made of metal in reality, it would stand to reason that the 3D model would have a metallic look to the leaf springs and axles on the undercarriage here too, so I don’t see the problem there. .
Profile
Posted: 11 July 2012 11:54 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2012-02-04
fixmypcmike - 11 July 2012 10:03 PM
You hit the nail on the head with that one.  It had applied a reflection rate of 100 to the side panels and I assume the door as well.  Probably the metal too, I didn’t check that yet.
Thanks soo much for that, it really saved me another hour of playing “Where is the problem?”  smile
Agreed the metal carriage isn’t a big problem, just very different from the promo pic.  Again it seems to be a reflection translation problem as it’s an older product and I’m using DAZ Studio Pro (which I forgot to mention in the first post).  I bet dialing it all down to a more muted setting and it will look wonderful.
Anyways problem solved, thanks again for your help.
 Signature
Profile
Posted: 12 July 2012 04:56 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
If the item is in an environment you could also remove the map from reflection colour, and probably lower the reflection strength, to get real reflections that match the lighting in the scene.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 12 July 2012 05:21 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2012-02-04
Thanks for that Richard.
The piece I’m working on is definitely environment heavy.
I’ll give your suggestion a try for sure.
 Signature
Profile
