Digital Art Zone
Surfaces and Ubersurface questions
Posted: 11 July 2012 07:24 PM   [ Ignore ]
New Member
Joined  2012-03-28
1. I’m trying to recreate a surface preset that a friend uses in Poser via the surfaces tab and UberSurface.  Would I be correct in assuming Poser’s transparency is the same as our opacity setting?  Poser also has edge and fall off values for transparency, are these settings available to us?
2. Is there a fractal sum setting and a scatter setting somewhere? The poser image has it linked to the transparency and a scatter linked to an alt diffuse, but I don’t see either anywhere when I load UberSurface.
3. When I get done editing the surface to my desire, if I use Save As… then shader preset, will I be able to re-apply this same setting to any new surface without having to load Ubersurface on the object first?
Profile
Posted: 11 July 2012 08:34 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
1.
  Yes
I think you would need to use shader mixer for that.
Again, I think that would be shader mixer stuff.
Yes
Profile
Posted: 11 July 2012 09:01 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-03-28
Thank you for the answers.  Guess I’ll finally try to learn the shader mixer.
Profile
Posted: 11 July 2012 09:14 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
It is likely that the edge settings for transparency are not vital and that you could sub in some sort of texture maps for the other stuff.
Profile
Posted: 12 July 2012 05:34 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
From my experience “edge” doesn’t really matter, it’s “falloff” that counts, this determines how see-through the black parts of the map are, we don’t have that in DS and afaik none of the 3rd party shaders (Uber etc) can’t deal with it either.
The attached image is how I do it in DS3’s ShaderMixer, I haven’t had the heart to look at DS4’s since all the bricks got changed, so I have no idea if it’ll work in 4 or not.
Two of the bricks have had a cosmetic change as what you see here is usually grouped into a “custom” brick, the math2 has had the value 2 section renamed, as that acts as the overall Opacity strength slider for the surface. The “falloff” is controlled by the mix brick, I’ve renamed a couple of things in this one too, Base becomes Black Base and it’s slider Black T-Max, and Layer became White Base with it’s slider White T-max. For most Trans maps I leave White T-Max at 1 and adjust the Black T-Max to control the black color in the trans map (ie if the “falloff” says 0.6 then you set Black T-Max to 0.4), but from time to time you’ll run into a trans map that doesn’t work right with that, for those I set Black T-Max to 1 and adjust White T-Max instead.
Image Attachments
 Signature
**shuffles of with a new headache** tongue wink
Profile
