Digital Art Zone
1 of 35
1
Updated Genesis Products List & Thing To Be Aware Of
Posted: 11 July 2012 03:50 PM   [ Ignore ]
Active Member
RankRank
Joined  2010-11-30
This is a list of Genesis products along with the current version numbers and some notes of things to be aware of when updating.
If a product has a Genesis version and other version it is indicate in most cases.  If the version numbers between the Genesis and other version are different that is indicated.  If just one version number is given an no distinction is given, the version number is the same for the Genesis and other version.
Products that have DSON specific files using the DSON Importer are indicated.  Some products can be used with the DSON Importer but do not require having installed DSON specific files for them.
This list is not finished and more items need to be added to it and items all ready on it may get new versions if they are updated again.
The main list became so large that it is currently split up into 2 parts.
Part 1 is in this post and a link to the post that has Part 2 is after Part 2.
Last updated refers to when I last updated the list not just one part of it.
Mike maintains the Non-Genesis Content with Metadata thread which lists what has been updated and the version number for those products.
That thread can be found at this links.
http://www.daz3d.com/forums/viewthread/2602/
A current listing of what is in the various bundles can be found at:
http://home.arcor.de/familie.reichow/3D/fwb1.html
The current bundle listing thread is at:
http://www.daz3d.com/forums/viewthread/1779/
Important thing to be aware of when updating:
1.) Some of the older uninstaller may not remove all files for the product you are removing.  The older Read Me files will still be left most of the time.
2.) If you start getting errors, can’t start Studio, or get told when installing an item Genesis can’t be located , you need to reinstall Studio.  One or more of the older uninstallers will remove some of the Genesis files and some Studio 4 files that it wasn’t supposed to I discovered a few days ago when I couldn’t launch Studio with out error messages after doing updates.
3.) Installing lots of content at once may cause Studio to have a problem when it goes to import the MetaData and crash. Periodically during your installs run Studio so the new MetaData can be imported in batches and not all at one, if you have several gigs to install. If you have to re-import all MetaData for Studio because of this or another problem, restart your computer first.
4.) Newer installers do not create a Read Me, which can make it difficult to determine what version you have of a product installed.  Its even more difficult if you have any older Read Me files too that didn’t get removed.
5.) If you bought the Genesis Evolution Morphs when they were first made available and they included as a free bonus the Genesis Evolution Expressions, you need to reset the Genesis Evolution Expressions product for them, as they are not part of the Genesis Evolution Morphs Bundle now.  If you did buy them and they included the Expressions when you bought them and you don’t see a Genesis Evolution Expressions product in you order history, you need to contact Daz’s support.
6.) If you mouse over the uninstaller for a product it will in some cases will let you know what version you have installed if the Read Me files are of no help Uninstallers will be in were you installed the content.. The uninstallers for most people can be found in:
/DAZ 3D/Studio/My Libary /Unistallers
or
/DAZ 3D/Studio3/Content/Uinstallers
7.) Some other items haven’t been updated but the separate MetaData installer isn’t in the reset as it isn’t needed.  The main installers are supposed to install MetaData.
The separate MetaData installers were made in the hopes that a future version of Poser would be able to read MetaData.
8.) If you have problems with MetaData after updating, like exclamation points on items,  duplicate MeatData items, the graphics for some items not showing up etc.  You will need to do this.
A.) Go into Content Database Maintenance and Reset the the Database by choosing Reset Database and hitting Accept.  This will remove all MetaData from the database and it will take several minutes to do.  When the reset is finished go to Step B.
B.) Go into Content Database Maintenance and chose Re-Import MetaData and hit Accept.  This will take several minutes for all the MetaData to be re imported.  It can be over an hour depending on how much content you have.  When the MetaData is has finished being re-imported go to step C.
C.) Check to see if this fixed your problems with the MetaData.  If it did your finished and have nothing else to do.  If it didn’t go to step D.
D.) Uninstall and re-instal the items that have problems.  Make sure the troubled items are fully uninstalled.  Make sure you are installing them into the correct folder as this can be the cause of the problem.  Repeat Steps A through C now.  If it fixed it your finished.  If it didn’t go to Step E.
E.) Contact Daz support and tell them what is going on and what you have done to try and fix it.  They can help you at this point.
These problems can occur with any product that has MetaData and not just Genesis specific ones.
9.) If you purchased a bundle and it doesn’t have the latest version of a product that it includes in it when you go to download the newer version contact Daz support and tell them the product that needs to be updated in the bundle and the name of the files in the bundle that aren’t current.
Support can take up to a few minutes to a week to get this fixed.
10.) If you get an error message when you try to download a file or your having the wrong file downloaded contact support so they can fix it.
11.) If you have Taiga for Genesis, Thorne has created a set of hair fit presets and posted some information on fitting hair if you are using that shape.
The hair fit presets are at:
http://www.ichloe.com/dollies/TaigaHairFitsPose.zip
The information on fitting hair to Taiga that Thorne posted can be found in this this thread:
http://www.daz3d.com/forums/viewthread/3238/
12.) These bundles had a name change to an item in them:
A)In the Victoria 5 Pro Bundle & Victoria 5 3D Model Pro Suite the Victoria 5 Geo-Grafted Genitalia has been replaced with the Genesis Female Genitalia.
B)In Michael 5 Pro Bundle & Michael 5 3D Model Pro Suite the Michael 5 Genitalia has been replaced with the Genesis Male Geniality.
13.) Richard Haseltine has written a script to fix the files that files that throw Duplicate IDs error in DAZ Studio 4.5.
The thread with information on it and links to download it is at:
http://www.daz3d.com/forums/viewthread/740/
14.) Taozen has a DAZ History Manager to help with seeing what has been updated.  It now checks to see if product pages indicates DSON files with your history.  The link to the tread that deals with the DAZ History Manager, that contains a download link for it is at.
http://www.daz3d.com/forums/viewthread/8672/P105/#133207
15.) Newer updates can contain DSON Core,Poser Companion, & Legacy Files depending on what program(s) you use determines what to install.
DAZ Studio 4 users install the Legacy files.
DAZ Studio 4.5 users install the DSON Core files.
Poser users install the DSON Core & Poser Companion files.
16.)  Genesis Starter essentials has its’ own listing on the update list.  Genesis Starter Essentials is included in the download files for Studio 4.5 and DSON Importer for Poser download files.
17.) Merc4D has DSON Poser Companion files for several products that can be gotten for free at the link below.
http://www.mec4d.com/store/index.php?_a=viewCat&catId=30
18.) Some uninstallers may not have obvious names and finding them can be difficult.
For example, the uninstaller for one version for Eastern Riding Wear was called B25RH.
If you can’t find and uninstaller for a product in the uninstaller folder of your My Library or other folder your uninstaller is is in, look for the product in your start menu programs folders for the product and run the uninstaller from that when you find it that way
Thanx to Cypherfox for putting the initial list in order and catching some duplicates on the old list.  Mike, Kendall, vwrangler and everyone else for adding stuff and making comments.
GENESIS PRODUCTS VERSION LIST
UPDATED 05-23-2013
3 in 1 Skinny Outfit (1.1) (DSON)
17 Chic (1.0) (DSON)
A3 and H3 Shapes for Genesis (1.1)
A4 and H4 for Genesis (1.2)
Aaron for Genesis Young Teen Justin (1.0) (DSON)
Abby for V4 and Genesis (1.0) (Genesis /  V4)
Abigail for V4 and Genesis (Genesis / V4)  (1.2) (DSON)
Abominable (1.0)
Actual Eyes 3 (1.0)
Addison (1.2 DSON Core & V4 / 1.1 Poser CF) & Legacy)  (Genesis / V4) (DSON)
Adrenaline Rush for Wicked Bolero (1.0)
Adventure Hero (1.0) (DSON)
Adventure Hero Textures (1.0) (DSON)
Adarian (1.0) (DSON)
Adarian Textures (1.0) (DSON)
Adventure Land Outfit (1.0) (DSON)
Adventure Land Outfit Textures (1.0) (DSON)
Adventure Lord (1.1)
Aiden for M5 (1.0)
Ailell (1.0)
Aiko 5 (1.1) (DSON)
Aiko 5 Premier Add-on Bundle (see separate entries for each product in the bundle)
Aiko 5 Pro Bundle (See separate entries for each product in the bundle.)
Aiko 5 Starter Bundle (See separate entries for each product in the bundle.)
Aiko Loves Freak (1.2) (DSON)
Air Bike (1.0) (DSON) (Note: Product is a vehicle with Genesis and M4 driver poses.)
Alexios Hair (1.1) (Genesis / Poser)
Alice Redemption (1.0) (DSON)
Alruna (1.4) (DSON)
Alruna Treasure (1.0)
Amaterasu (1.0) (Genesis /  V4)
Amethyst Fantasy for Genesis (1.2)
Amras (1.0)
Anastasiya for A5 (1.0) (DSON)
Andrea for Genesis Young Teen Julie (1.0) (DSON)
Andrei for Freak 5 (1.1) (DSON)
Andromedas Legend for Genesis (1.0)
Anime Dress for Genesis (1.4)
Anime Dress for Genesis Textures (1.2)
Anime Nurse Textures (1.1)
Anime Nurse Uniform for Genesis (1.2)
Anime School Girl Textures (1.1)
Anime School Girl Uniform (1.3)
Anubis (1.8)
Apprentice Mage in the Tower (1.0) (DSON)
April Showers for Genesis Female (1.0) (DSON)
April Showers Poses for Genesis Female (1.0) (DSON)
Aranmenel   (1.0)
Arashi for Hiro 5 (1.0) (DSON)
ArtemisX for Genesis (1.1)
Asian Faces (1.0) (DSON)
Asobi (1.1 Asobi & ToXic Toon Amy Hair:)
Asobi Bundle (1.2 Outfit / 1.1 Asobi & ToXic Toon Amy Hair: )
Asobi Outfit (1.2)
Astral for GIS (1.1)
Athlantya for Genesis (1.0) (DSON)
Audacious for Defiant (1.0)
Aven Clothing for Genesis (1.3)
Aven for Genesis Bundle (1.3)
Aven for Genesis (Character) (1.3)
Aven Hair for Genesis (1.3)
Azumi for Aiko (1.0) (DSON)
Ballerina Assembly Kit (1.4 Genesis / 1.0 V4 & Laura) (DSON)
Baby for Genesis (1.1)
Bad Guy for Genesis (1.1)
Barbarian Boots for Genesis (1.0) (DSON) (Previous older version had the same1.0 designation the newer version has.)
Barbarian Warlord for Genesis (1.0) (DSON)
Bartender for Tavern Keeper (0.9)
Beasts and Brutes (1.01)  (A very older version had the same1.01 designation the newer version has)
Beautiful Fingers for Genesis (1.0)
Bella Hair (1.4) (Genesis / V4) (DSON)
Benjamin for M5 (1.3) (DSON)
Bewitching for Genesis (1.2) (DSON)
Bobby Soxer (1.1)
Boots and Belt for SuperSuit (1.2)
Bot Genesis (1.1) (DSON)
Boudoir Bliss for Genesis Female (1.1) (DSON)
Bow Dress and Boots (1.0) (DSON)
Bow Dress and Boots Textures (1.0) (DSON)
BR Skirt for Genesis (1.1)
BraxtonM5 (1.1)
Breezy (1.2)
Brennan for Genesis (1.2)
Brutes Bruisers Thugs and Tough Guys for Freak 5 (1.0) (DSON)
Buccaneer Basic for Genesis (1.5) (DSON)
Buccaneer Basic Textures (1.2)
Bugbear for Genesis (1.0)
BunnyGirl for Genesis (1.0) (DSON)
Bus Maxis (1.1) (DSON) (Note: Product is a vehicle with Genesis and M4 driver poses.)
Candace for Stephanie 5 (1.0)
Candace for Stephanie Bundle (See separate entries for each product in the bundle.)
Canis Lupus Rex for Wolf King (1.0) (DSON)
Cape for Supersuit (1.1)  (DSON)
Capsces Poses Hiro 5 (1.0) (DSON)
Caput Caseum (1.0)
Caput Caseum Textures (1.0)
Car Boss (1.1) (Note: Product is a vehicle with Genesis and M4 driver poses.)
Carhop for Genesis Female (1.2)
Carrara Skin Shaders For David 5 (1.0)
Casual 1950 for Genesis Female (1.0)
Casual 1950 for Genesis Male (1.1)
Casual Afternoon for Genesis (1.2)
Casual Afternoon Textures (1.0)
Casual Friday (1.0) (DSON)
Casual Friday Textures (1.0) (DSON)
Casual Halter and Shorts (1.0) (DSON)
Casual Halter and Shorts Textures (1.0) (DSON)
Casual Short Dress (1.1) (DSON) (Note: Previous version was at 1.1, but had no DSON files and different installer names)
Casual Short Dress Textures (1.1) (DSON) (Note: Previous version was at 1.1, but had no DSON files and different installer names)
Casual Surf Wear for Genesis (1.2) (DSON)
Catgirl Genesis (1.3) (DSON)
Chablis for Genesis/V4 (1.1) (Genesis / V4)
Chelsea Hair (1.5) (Genesis / V4) (DSON)
Cherry Blossom Hair (1.0) (Genesis / V4)
Chibi Boy for Genesis (1.1)
Chibi Girl for Genesis (1.0)
Classic Rolled Hair for Genesis (1.2) (DSON)
Classic Swimwear Genesis (1.0)
Classics Bundle for Genesis (See separate entries for each product in the bundle)
Clothing Cleavage Modifier (1.2)
Clown (1.1)
Clown Textures (1.1)
Club Dress (0.9)
Colonel Chaos (1.0) (DSON) (Previous older version had the same1.0 designation the newer version has.)
Colonel Chaos Textures (1.0) (DSON)
COLORation Bella (1.0)
Colors for Elements Hair (1.1) (DSON) (Note: This product works with Elements Hair and Elements Hair for Genesis.)
Colors for Georgina Hair (1.0) (DSON) (Note: This product works with Georgina Hair and Georgina Hair for Genesis.)
Colors for Philly Hair (1.1) (DSON) (Note: This product works with Philly Hair and Philly Hair for Genesis.)
Colors for Knotty Tails Hair (1.1) (DSON) (Note: This product works with Knotty Tails Hair and Knotty Tails Hair for Genesis.)
Colors for Love Me Hair (1.0) (DSON) (Note: This product works with Love Me Hair and Love Me Hair for Genesis.)
Colors for Minnie Bow Hair (1.0) (DSON) (Note: This product works with Minnie Bow Hair and Minnie Bow Hair for Genesis.)
Colors for Sandy Hair   (1.1) (DSON) (Note: This product works with Sandy Hair and Sandy Hair for Genesis.)
Colors for Swim Cap Hair (1.0) (DSON) (Note: This product works with Swim Cap Hair and Swim Cap Hair for Genesis.)
Colors for Tears Hair (1.1) (DSON) Note: This product works with Tears Hair and Hair Tears Hair for Genesis.)
Colors for Timeless Male Hair (1.1) (DSON) (Note:This product works with Timeless Male Hair and Timeless Male Hair for Genesis.)
Conjurer for Priestess (1.1) (DSON)
Cool and Sexy Poses For Stephanie 5 (1.0) (DSON) (Note: Older version was 1.0 also, but had no DSON files)
Cool and Squaresville (1.0)
Cool Sports for Genesis (1.1)
Corbin for M5 (1.0)
Corvena (1.0) (Genesis / V4) (DSON)
Corvena Bundle (see separate entries for each product in the bundle)
Corvena Jewelry (1.0) (Genesis / V4) (DSON)
Cowboy Gumdrops Genesis (1.0)
Create ‘Fiery Genesis’ in DAZ Studio (1.1)
Creation Engineer (1.0) (Updated to work in DS 4 and extras added to the DS4 and DS4.5 versions)
Crimson Nights for Onyx Male (1.0)
Cuban Diabolo for Genesis (1.6)
Curbside Cuties (1.1)
Cute3D Combat Boots (1.0)
Cute3D High Tops (1.0)
Damaris Hair (1.1) (Genesis / V4)
Danties for Boudoir Bliss (1.0)
Dark Embrace (1.0) (DSON)
Dark Moods for Genesis (1.0)
Dark Moon (1.0) (DSON)
Dark Moon Textures (1.0) (DSON)
Dark Priest Poses for M5 (1.1) (DSON)
Dark Warriors for GIS (1.0)
Darkwave (1.0)
David 3 for Genesis (1.0)
David 5 (1.2 DSON Core / 1.0 Poser CF) (DSON) (Note: Older 1.1 DSON Core can still be downloaded.)
David 5 Fashion Poses (1.0) (DSON)
David 5 Pro Bundle (See separate entries for each product in the bundle.)
David 5 Starter Bundle (See separate entries for each product in the bundle.
Dawn for V4 and V5 (Genesis / V4) (1.1)
Daydream (1.0) (DSON)
Day Dreamer for Genesis (1.3)
DAZ Monstrosities: Infernal Behemoth (1.0) (DSON)
DAZ Monstrosities: Skullcrusher Ogre (1.0) (DSON)
Dead Nation Boots (1.0) (Note: When using them with the David for Genesis shape the 1.0 version may have issues.)
Dean for David 5 (1.1) (DSON) (Note older 1.0 files can still be downloaded.)
Deborah for Julie (1.0) (DSON)
Defiant for Genesis (1.6)
Delilah for Genesis (1.4)
Delivery Driver Bundle (See separate entries for each product in the bundle.)
Delivery Driver Extension (1.1)
Delivery Driver for Genesis (1.2)
Denver Hair (1.1)
Derek for Freak 5 (1.1) (DSON)
deWinter (1.0) (DSON)
deWinter Textures (1.0) (DSON)
Diner Waitress for Genesis Female (1.1 Poser CF / 1.3 Legacy & DSON CORE))
DMs Circle (1.0) (V4 & V5)
DMs Steps to Eternity (1.0)
Dot Check (1.0)
DP - Carrara Shaders For Aiko 5 (1.0)
DragonLord for Genesis (1.3) (DSON)
Dragon Poses For Hiro 5 (1.0) (DSON)
Dragon Princess (1.0) (DSON)
Dragon Princess Jewels (1.0) (DSON)
Dragon Queen for Genesis Female (1.0) (DSON)
Dragon Rage (1.0) (DSON)
Dragon Rage Textures (1.0) (DSON)
Dragon Touched for Dragon Princess (1.0) (DSON)
Dryden for Hiro 5 (1.0)
Dragon Slayers (1.0)
Dragon Witches for Dragon Queen (1.0) (DSON)
Drakon (1.1)
Dress Collection Two for Genesis V4 (1.2)
Dryden for Hiro 5 (1.0) (DSON)
DSON Importer for Poser (1.0.0.27 Importer /  1. 11 PF Companion & DSON Core files for Genesis Starter Essentials)
Dynamic Supersuit Set 1 Worlds Finest (1.0)
Dynamic Supersuit Set 2 Cosmic Gods (1.0)
Dynamic Supersuit Set 3 The Mystics(1.0)
Dynamic Supersuit Set 4 Hero Accessories (1.0)
Dynasty Textures for Wicked Pyjama Party (1.1) (DSON)
Eastern Beauty (1.1) (DSON)
Eastern Beauty Volume 2 (1.0) (DSON)
Eastern Riding Wear (1.3) (DSON)
Easy Going Poses for Michael 5 (1.2) (DSON)
Effortless Cool for Genesis Male (1.1)
Effortless V5 Poses (1.0) (DSON)
Eldorin for Genesis (1.2)
Eldorin Textures (1.0)
EleBeast (1.1)
Elements Hair for Genesis (1.1) (DSON)
Elven Dress for Genesis (1.6) (DSON)
Elven Hair for Genesis (1.2) (DSON)
Elven Warrior for Genesis (1.3)
Emiko for A4 and A5 (1.0) (A4 & A5) (DSON) (Note: Only, the A5 version has DSON files. The A4 version doesn’t need them.)
Enamore Mage for Genesis   (1.0)
Enchanted for Genesis (1.2)
Enchanted Textures (1.1)
Enticing Ladies (1.1)
Epic Wings (1.6) (DSON)
Epic Wings X-pansion (1.2) (DSON)
Erynion for Elven Warrior (1.0)
Ethnicity for Genesis: African (1.2)
Ethnicity for Genesis: Asian (1.2)
Ethnicity for Genesis Bundle (1.2)
Ethnicity for Genesis: Native American (1.2)
Ehawee for Hitomi (1.1)
Evan Hair (1.2)
Everyday 1950 for Genesis Female (1.1)
Expressive for Genesis (1.1) (DSON)
Extreme Heroes AXS (1.0)
Extreme Heroes Ultimate Poses (1.0)
Faces of Hiro 5 (1.0)
Faces of Teens (1.0) (DSON)
Fairytale Dress for Genesis (1.3)
Fantasy Accessories for Pharaohs for Genesis Female (1.1) (DSON)
Fantasy Poses for Aiko 5 (1.0) (DSON)
Fantasy Wrap for Genesis (1.4)
Fantasy Shapes for Genesis (1.6)
Fashionista Model Poses For Victoria 5 (1.0)
Female Business Suit (1.0) (DSON)
Feminine Touch for Genesis (1.1) (Note: Was updated in August of 2012, but installer version number wasn’t updated)
Fierce for Lion Queen (1.0) (DSON)
Fifties Favorites for Casual 1950 Male (1.1)
Finger Wave Bob for Genesis (1.1)
Flat Top Hair (1.0) (Genesis & M4)
Flora Lace Dress for Genesis (1.0) (DSON)
Florabelle for V4 and Genesis (Genesis / V4) (1.3) (DSON)
FM Fight Club Boxing Shoes (1.2)
FM Fight Club Clothing (1.1)
Forest Scout (1.1)
Forever Fantasy Poses (1.0) (DSON)
Four Arms for Genesis (1.1) (DSON)
Foxy and Wolfie for Genesis (1.0) (DSON)
Frankie Bundle (See separate entries for each product in the bundle)
Frankie Outfit (1.2) (Genesis /  V4) (DSON) (Note: Only the Genesis version has DSON files.)
Frankie Von Stein (1.1 Poser CF/ 1.0 Genesis DSON Core & V4 files.) (DSON) (Note: Only the Genesis version has DSON files.)
Freak 5 Action Poses (1.0) (DSON)
Freak 5 Big Sweater (1.0) (DSON)
Freak 5 Pro Bundle (See separate entries for each product in the bundle)
Freak 5 Starter Bundle (See separate entries for each product in the bundle)
Full & Feathered Hair for Genesis (1.0)
Fun and Flirty (1.0)
Future Cop For Genesis (1.3)
G4 and F4 for Genesis (1.3)
Gabi for V5 (1.4) (DSON)
Gabriella for V5 (1.0)
Galactic Corps Defender (1.0) (DSON)
Galactic Corps Defender Textures (1.0) (DSON)
Galaxy for Genesis (1.0)
Geishas for Aiko 5 (1.0) (DSON)
Gem for V5 (1.1)
Gen 3 Iconic Shapes for Genesis (1.1 A3 and H3 / 1.1 Stephanie 3 and Freak / 1.0 V3 and M3
Gen 4 Iconic Shapes for Genesis (1.3 G4 and F4 / 1.2 A4 and H4)
Genesis Alive (1.0)
Genesis Anime Starter Bundle (see separate entries for each product in the bundle)
Genesis Basic Clothing Rig Kit (1.1 Genesis Clothing Rig Kit / 1.0 Genesis Clothing Developers Kit PDF)
Genesis Basic Wear for Women (1.2)
Genesis Battle Ready Bundle (see separate entries for each product in the bundle)
Genesis Bikini (1.4) (DSON)
Genesis Bracers (1.2)
Genesis Cavalier (1.0)
Genesis Creature Creator Bodies (1.3)
Genesis Creature Creator Bundle (1.3)
Genesis Creature Creator Heads (1.3)
Genesis Cupid (1.1)
Genesis Expressions and Face aniBlocks (1.1)
Genesis Evening Gown (1.0)
Genesis Evening Gown Textures (1.0)
Genesis Evolution Expressions (1.4 Note: the size for these are PC 6.53 MB / Mac15.2, earlier 1.4 files had a different size.)
Genesis Evolution: Body Morphs (1.4 Note: The size for these are PC 7.26 MB / Mac 16.0 MB, earlier 1.4 files had a different size.)
Genesis Evolution: Head Morphs (1.5)
Genesis Evolution Morph Bundle (see separate entries for each product in the bundle)
Genesis Evolution: Muscularity (1.0)
Genesis Eyebrows (1.1)
Genesis Female Geo-Grafted Genitalia (1.6 DSON Core & Legacy / 1.7 Poser CF) (DSON)
Genesis Male Geo-Grafted Genitalia (1.3) (DSON)
Gentleman Adventurer Poses for D5 (1.0) (DSON)
GenX AddOn Gen3 for A3 and H3 (1.2)
GenX AddOn Gen3 for S3 D3 and F3 (1.2)
GenX AddOn Gen3 for V3 and M3 (1.2)
Genesis Generation X (1.2)
Genesis Generation X (Upgrade from Gen4) (1.2)
Genesis Michael Victoria Combo Bundle (see separate entries for each product in the bundle)
Genesis Nano Suit (2.1)
Genesis Poses for Moonshines Diner Int Ext (1.0)
Genesis Ranger (1.5) (DSON)
Genesis Ranger Textures (1.1)
Genesis Scout (1.2)
Genesis Scout Textures (1.0)
Genesis Starter Bundle (see separate entries for each product in the bundle)
Genesis Starter Essentials (1.13) (Note: Texture Templates can be downloaded from the Read Me page.)
Genesis Timeless Fantasy Textures (1.0)
Genesis Ultimate Military Basic (1.0) (DSON)
Genesis to Poser CR2 (1.2)
GenX AddOn Gen3 Bundle (see separate entries for each product in the bundle)
Georgina Hair for Genesis (1.0) (DSON)
Ghost Hoodie for Genesis (1.0) (DSON)
GIS for Genesis Male (1.0)
Glute and Breast Movement for Genesis (1.1) (DSON)
Gnome for Genesis (1.0)
GOM Genesis Male Morphs (1.1)
Gorilla for Genesis (1.1)
Gossip for Genesis (1.2)
Goth Chick (1.1) (DSON)
Green and Gold Onyx (1.0)
Gregoria Hair (1.1 Genesis & Gen 4)
Gunner for David 5 (1.0) (DSON)
G-Suit, Bodysuit for Genesis (1.1)
Hairdresser Modular Hair (1.0)
Hampton Hair (1.1) (Gen4 / V5) (Note: This hair does not require any additional files to work with Genesis in Poser.)
Handsome Head Morphs for Genesis (1.0)
Handy for Genesis (1.1) (DSON)
Hash Slingers for Short Order Cook (1.0)
Hat Hat Hat… (1.1) (Genesis, S4, & V4)
Haley for Young Teen (1.0) (DSON)
Hayden for Young Teen (1.0) (DSON)
Hellfire Poses (1.0) (DSON)
Hello Sailor (1.1)
Heracles for Genesis (1.1)
Hero vs. Anti-Hero (1.0)
Hey Baby (1.0)
Highlander: Wildenlander for Genesis (1.2)
Hip and Happening Textures (1.0)
Hip Retro Dress (1.1) (DSON)
Hip Retro Dress Textures (1.1) (DSON)
Hiro 5 (1.0)
Hiro 5 Clothing and Hair ONLY Bundle (see separate entries for each product in the bundle)
Hiro 5 Hair (1.0)
Hiro 5 Starter Bundle (see separate entries for each product in the bundle)
Hiro 5 Pro Bundle (see separate entries for each product in the bundle)
Hitman (1.0) (DSON)
Hitman Textures (1.0) (DSON)
Hitomi 3D Anime Girl for Genesis (1.4)
Hitomi’s Day Out (1.3)
Hitomi Summer Mini Outfit (1.1)
HomeslipperZZ for Genesis (1.3) (DSON)
Hooded Cloak for Genesis (1.0)
Ideal Beauty Shapes: Feet for Genesis (1.0) (DSON) (Note: Installers were updated to fix a bug, but version number wasn’t changed.)
Imelda (1.4)
Interjection Booster Shot One (1.2)
Intriguing Poses for Genesis Female (1.0) (DSON)
Iolanthe Dress (1.1)
Jack of Hearts for Genesis (1.0)
Jade Assassin (1.2)
Jade Hair for Genesis (1.1) (DSON)
James for M5 (1.2) (DSON)
Japanese School Uniform (1.0) (DSON)
Japanese School Uniforms For Boys (1.0)
Jasmin for Genesis (Bundle) (see separate entries for each product in the bundle)
Jasmin for Genesis (Character) (1.2)
Jason for Genesis (Bundle) (see separate entries for each product in the bundle)
Jasmin for Genesis (Clothing and Accessories) (1.0)
Jason for Genesis (Character) (1.2)
Jason for Genesis (Clothing) (1.0)
Jason/Jasmin for Genesis (Uber Bundle) (see separate entries for each product in the bundle)
Jazlyn for Genesis Bundle (1.1)
Jazlyn for Genesis Character and Hair (1.1)
Jazlyn for Genesis Clothing and Accessories (1.1)
JeanZ for Genesis (1.0) (DSON)
Jersey Dress Expansion (1.1) (DSON)
Jersey Dress Outfit (1.1) (DSON)
Jeweled Finery (1.2)
Jesse for Genesis (1.0) (DSON)
Jingle Fae (A4, V4,  & V4 Elite / Genesis) (1.3)
JSkirt For Genesis (1.0)
Just Chill (1.0)
Just Jokin’ V5 (1.6 Genesis / 1.5 V4)
Just Posh (1.0)
K-Nicky Hair for Genesis (1.2) (DSON)
Kamiko for Genesis (1.0)
Kameez for Genesis (1.2)
Kameez Textures (1.1)
Katumi Dress (1.2)
Katumi Dress Textures (1.1)
Katya (1.0)
Kaylee for V4 and V5 (1.0) (V4 / V5)
Keira for Stephanie 5 (1.1)
Kenjutsu Sword (1.0) (DSON) (M4, V4, M5, & V5) (Note: product is a prop but includes poses for M4, V4, M5, & V5.)
Kenzi Outfit for Genesis (1.1) (DSON)
Kimberly for Genesis Character (1.0) (DSON) (Note: Has no Poser CF.)
Kimberly for Genesis Complete (1.0) (DSON) (Notes: Has no Poser CF.  See separate entries for other included products.)
Kiyoko (1.1)
Knotty Tails Hair for Genesis (1.2) (DSON)
Lady Blaze for Genesis (1.1)
Lady Dress For Genesis (1.1)
Lady Elf Hair for Genesis (1.2)
Latex Hero (1.0) (DSON)
Latex Hero Textures (1.0) (DSON)
Leather Jacket for Genesis (1.1) (DSON)
Leathered Up (1.0) (DSON)
Leathered Up Textures (1.0) (DSON)
Leafy Suit for Genesis (1.1) (DSON)
Legion for Genesis (1.4)
Legion for Genesis Textures (1.1)
Lenore Hair Trio (see separate entries for each product in the bundle)
Leyla (1.0) (Genesis & V4)
Lily Nymph for Genesis (1.0) (An older version was at 1.0)
Lion Queen for Genesis Female (1.0) (DSON)
Liquid Halo On Sky 16 for Genesis (1.3)
Lone Wolf for Genesis (1.2)
Look At Me! Eyes 2 (1.0)
Lord of the Wolves (1.0) (DSON)
Love Me Hair for Genesis (1.1) (DSON)
Lucrezia (1.0)
Luminous Casual Hair (1.0)
Luka Hair (1.4) (Genesis / V4) (DSON) (Note: Only Genesis version has DSON files.)
Lycan Hunter (1.1) (DSON)
Lynettes Dark Nights for Genesis (1.1)
M5 Casual Male (1.5) (DSON)
M5 Firearms with Expressions and Poses (1.1)
M5 Photographic Poses (1.2) (DSON)
Making Faces for Aiko 5 (1.0) (DSON)
Mall Girl for Genesis (1.0) (DSON)
Manami (1.1) (DSON) (Genesis & V4) (Notes: has No Poser CF.)
Manly Men M5 (1.2)
Magna Hart for Genesis (1.5) (DSON)
Magna Hart for Genesis Textures (1.1)
Marauders for Genesis (1.5)
Mardi Gras Supersuit (1.1)
Mavka for Genesis (1.1) (DSON)
Mavka Hair for Genesis (1.1)
Mavka Starter Bundle (see separate entries for each product in the bundle)
May Day for April Showers (1.0) (DSON)
MBS Expansion 1 (1.0)
MBS Expansion 2 Suit Props (1.0)
Mean Streets for Genesis Male (1.0) (DSON)
Medea (1.4)
Medieval Female Peasant Clothing for Genesis (1.3)
Medieval Male Peasant Clothing for Genesis (1.2) (DSON)
Mega Mood Expressions (1.2)
Mellow (1.1)
Men’s Night Life (1.0) (DSON)
MFD for Genesis Expansion Pack 1 (1.1)
MFD for Genesis Expansion Pack 2 (1.1)
Michael 5 (1.3 M5 General Poses / 1.1 Michael 5 / 1.3 Underwear) (DSON)
Michael 5 3D Model Pro Suite (See separate entries for each product in the bundle)
Michael 5 Elite Hair (1.1)
Michael 5 Elite Skin Texture Dave (1.0)
Michael 5 Pro Bundle(see separate entries for each product in the bundle)
Michael 5 Starter Bundle (see separate entries for each product in the bundle)
Midnight Watchmen for Night Guard (1.1) (DSON)
Minnie Bow Hair for Genesis (1.0) (DSON)
Mindy for V4 and Genesis (1.1) (Genesis / V4)
Minotaur for Genesis (1.0)
Misfit for Genesis (1.0) (DSON)
Misfit for Genesis Textures (1.0) (DSON)
Mistress of the Lions (1.0) (DSON)
Mitsu Hair for Genesis (1.4) (Note: Was updated on 2-26-2013, but version number wasn’t updated.)
Miyu (1.4)
Modern Muses Summer (1.0) (Genesis V4 / V4 Elite Body & Victoria 4.2 Morphs ++ / V5)
Modern Muses: Tamesis (1.1) (Genesis / V4)
Momotsuki (Pink Moon) Hair (1.0) (DSON)
Monster Details for Genesis (1.5) (DSON)
Moon Rod (1.0) (DSON) (Note: Product is a vehicle with Genesis and M4 driver poses.)
Moody for Dark Moods (1.0)
Moonshines Diner Exterior Poses (1.0)
Moonshines Diner Interior Poses (1.0)
Moonsong Hair for Genesis (1.2)
More Goth for Goth Chick (1.0) (DSON)
Morphing Business Suit (1.0)
Morphing Business Suit Bundle (see separate entries for each product in the bundle)
Morphing Fantasy Dress for Genesis (1.5) (DSON)
Morphing Fantasy Dress Unimesh Fits (1.1 Gen 4 MFD Unimesh Fits / 1.5 MFD Genesis) (DSON)
Morphing Square Toe Sandals (1.0) (DSON)
MoveS for Hitomi (1.5) (DSON)
Mountain Troll for Genesis (1.0)
Motorcycle Helmets for Genesis (1.2)
Moyras Lingerie Boutique Honeymoon (1.0)
Mr Hyde for Genesis (1.3)
MS-Lycan (1.2)
Muse for Genesis Female (1.0) (DSON)
Musings for Muse (1.0) (DSON)
Mystical Touch (1.0) (Gen 4 / Genesis)
PART 2 Link:
http://www.daz3d.com/forums/viewreply/188982/
Profile
Posted: 11 July 2012 04:32 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2005-11-06
Question, what prompted you to even think of checking to see if they were updated? Any idea why they all seemed to be updated based off your list? I can’t find any sticky that mentions anything changing.
 Signature
Regards, Michael
“Documentation? Who needs documentation, just open it and learn!”
My DeviantArt Gallery
Profile
Posted: 11 July 2012 05:44 PM   [ Ignore ]   [ # 2 ]
Active Member
RankRank
Joined  2010-11-30
A lot of the older items had some duplicate files that cause a problem with the 4.5 RC from a post I read & some of the items got updated for other reasons.
I got promoted to check everything after readings some posts that seemed to indicate that just about all of the older Genesis items had gotten updated, but had no idea of exactly which ones except for a few.
The list came out of desire to prevent others from having to try and figure out what needs to be reset and in the hopes of having a Genesis update thread like the non-Genesis MetaData one will get created and maintained. Also , some of the few update threads I did find didn’t have the most current version of a few items listed I discovered after doing a reset..
Profile
Posted: 11 July 2012 06:35 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2012-02-04
Thanks for taking the time to make this list and the warnings. There are two things the upset me (and many others, I’d guess) about the DAZ product update approach. They don’t tell you that an update is available, and once you find it on your own, you still aren’t told what changed. Just venting….
Profile
Posted: 11 July 2012 07:47 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2012-02-07
Greetings,
Duplicate M5 Elite Hair, Genesis Baby, and Tassel Loafers removed, and sorted.  Cleared out as list moved up to the top.
Thanks for this!
— Morgan
 Signature
Want to be notified when items on your wishlist get discounted?  Want to sort and view your wishlist better, or to see ALL the current discounts? http://3dwishlist.com/demo
Want the old forums to work, or tabs gone on details pages?  How about ‘Show Specials’ back on the wishlist?  On Firefox (with Greasemonkey) or Chrome: http://userscripts.org/scripts/show/133738
Profile
Posted: 11 July 2012 07:58 PM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Thanks for the list—I’ve been working on one as well, so I’ll compare the two and let you know if I have any additions/changes.
For those who were asking, most of the updates were in March or April.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 11 July 2012 09:46 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2009-01-09
A few other items include in this other thread.
 Signature
VWrangler at deviantArt (NSFW for some images; login required to view those)
Profile
Posted: 11 July 2012 11:32 PM   [ Ignore ]   [ # 7 ]
Active Member
RankRank
Joined  2010-11-30
Thanks for catching the duplicates and putting them in order.  I updated the main list and added a few more products to it. More will be added in the next day or two.
These have been added and are in correct order on the main list.
Defiant for Genesis (1.5)
MS-Lycan (1.2)
Brennan for Genesis (1.1)
Elven Warrior for Genesis (1.1)
Ethnicity for Genesis Bundle (1.1)
Genesis Creature Creator Bundle (1.2)
Just Jokin’ V5 (1.4)(Genesis/V4)
Genesis Evolution Expressions (1.4)
Genesis Evolution Morph Bundle (1.3 Body / 1.4 Head)
I need to check the version number on a few items not currently on it like Outland Marauder for Genesis, before I add them.
Profile
Posted: 12 July 2012 07:56 AM   [ Ignore ]   [ # 8 ]
Power Member
Avatar
RankRankRank
Joined  2009-08-05
What exactly does it mean when the duplicate msg comes up? What does it do, what is the issue? I just click ok and my product still works like it should? I’m not going through all this effort to update when all I can do is click ok on the error msg and continue working just fine.
 Signature
My Daz Store
My Rendo Store
Latest Products
FaceWeight for Genesis
Toe Control for Genesis
Profile
Posted: 12 July 2012 07:57 AM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2005-06-08
Thanks for the list!
 Signature
Eyebrow-Free Face Textures — A List
. . . wasn’t actually much like a lobster dinner.
Profile
Posted: 12 July 2012 11:45 AM   [ Ignore ]   [ # 10 ]
Power Member
Avatar
RankRankRank
Joined  2011-07-31
Thanks for the list.  Just skimming through I can see that I have a lot of resetting to do.  Guess I’ll print out the list(s) and check them off as I update.
 Signature
AtticAnne in Austin TX
FREE GANGSTER RPG GAME
Profile
Posted: 12 July 2012 12:28 PM   [ Ignore ]   [ # 11 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
13302 Day Dreamer for Genesis is at 1.3 now
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 12 July 2012 01:27 PM   [ Ignore ]   [ # 12 ]
Power Member
RankRankRank
Joined  2011-11-16
Where do you see the version number of your item in inventory, or of the current one online?
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 12 July 2012 01:31 PM   [ Ignore ]   [ # 13 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
In my case, I reset “Day Dreamer for Genesis” and as of 12-Jul-2012 14:49EDT the filename I was given was:
13302_DayDreamerGen_v1.3_ds.exe
So, according to the filename the version is “1.3”
That’s what I’m working from.
Kendall
 Signature
Profile
Posted: 12 July 2012 03:08 PM   [ Ignore ]   [ # 14 ]
Active Member
RankRank
Joined  2010-11-30
Thanks Kendall for the addition.
Fixed:
Boots and Belt for SuperSuit (1.2) so it is in order on the main list now.
Removed duplicate of Genesis Bikini that had a different version number.  It got updated twice. The current version is 1.2.
Added:
Beasts and Brutes (1.0)  (The old version was 1.01 for some odd reason)
Evan Hair (1.2)
Hitomi’s Day Out (1.2)
Medieval Female Peasant Clothing for Genesis (1.2)
Outland Marauder for Genesis (1.6)
Pyrit Hair (1.2) (Genesis/V4)
Sexy Silky For Genesis (1.1)
Starla Hair (1.1) (Genesis/V4)
Victoria 5 Geo-Grafted Genitalia (1.3)
Added some more notes.
Some other comments:
A script was made to deals with the duplicate formula warnings that 4.5 RC gives that you could run so everything didn’t need to be uninstalled and reinstalled I’m trying to find the post that was made on it. and put a link to it in the notes.
If some one happens to rest the V5, M5, Hitomi, or Classics Bundle please post the files that got updated and I’ll add them in since I didn’t type them up and only gt a few of the current ones from other threads.  One of the hair styles in the V5 bundle has a different version number for the Genesis and Gen4 version of it if I remember correctly.
Profile
Posted: 13 July 2012 08:22 AM   [ Ignore ]   [ # 15 ]
Power Member
RankRankRank
Joined  2011-11-16
Kendall Sears - 12 July 2012 01:31 PM
Kendall
Hehe, thanks Kendall. It’s surprising how easy it is to miss something right in front of our face but I have that problem in spades at times wink
 Signature
Profile
1 of 35
1
