Daz Studio 4.6 Pro (current version) extremely slow on saving scenes.
hacsarthacsart Posts: 665
Daz Studio 4.6 Pro (current version) extremely slow on saving scenes and yet one more wrinkle (the mouse losing focus bug when adjusting slders is back wi' a wannion). Current version of Studio Win.8,1 64 bit, 8GB RAM 4.5Ghz AMD.. A scene with 3 figures (2 M4 and one V4.2) 5 lights (no deep shadow mapping) and a base room scene) takes about 15 minutes to save).. DAZ is the only thing running, drive is a SATA and is not fragmented and has well over 1/2 Tb free. No speed issues on file operations outside of DAZ.. DAZ log file, no errors or warnings. Also Perfmon shows Daz running with an average of 25% CPU and 8 threads while saving.. No bottlenecks indicated overall by Perfmon or Resource Monitor
help? thoughts?
Thanks!
Edited to place full text of question in post
  • KeryaKerya Posts: 9,378
    Somebody had the problem that his desktop icon got set to Vista compatibility mode for whatever reason.
    After rectifying that DS ran well.
    Just trying to help ...
  • Richard HaseltineRichard Haseltine Posts: 42,025
    Using legacy content, such as V4 or M4, is slower than using content which already exists as a DS4.x asset.
    Oh yes, but only the first time, right? A second time the scene should save faster because DS has saved the data to the Data folder?
    I think so, maybe. I must admit to not having used much legacy content, at least for morph- and bone-heavy human figures, recently.
  • hacsarthacsart Posts: 665
    well.. FWIW I now get the following error in my logs..
    "WARNING: dzvalentinaobjectdatabase.cpp(38): DB Insert error: "FILE: ..\..\sources\VKernel\Fbl\prot\Structure\VarChar\FBL_VarCharFile.cpp FUNCTION: fbl::VarCharFile::BinarySearch LINE: 497" Varchar data "" is corrupted.:
    Sigh..
    Well. I did find a cure.. Deleted all occurrences of the content databases, removed and re-installed the CMS service, and then deleted and remapped my content directories. Had Studio scan for new content, then reset and compacted the new databases. I archived the original databases before deletion, I think its time to have a look at them. IF they are SQL compatible, I should be able to see what the problems were.
