Poser 2014 Ram Allocation
I have poser 2014 with latest updates and i render big scenes but they take forever and poser never uses more than 1.5 gb of ram..I have an Intel core2 Quad 2.8 ghz 8gb ddr2 6400 ram..I would like poser to use more ram.
  • mjc1016mjc1016 Posts: 14,998
    Yes...but what is your OS...
  • edited December 1969
    windows 7 Ultimate x64
  • prixatprixat Posts: 1,028
    It sounds like you're using a 32bit version of Poser.
    it says in task manager FFrender64.exe
  • KeryaKerya Posts: 9,352
    edited March 2014
    You say big scenes ... do you mean a big picture (Pixelwise) or a big scene with many items?
    Because if it is just pixelsize big, you don't need that much RAM.
    RAM is holding the textures and so on - if there aren't many textures, it doesn't need much RAM.
    The rendertime depends on your CPU, and that sounds fine.
    Did you look in taskmanager whether all cores are more or less working when rendering?
    If no, you could take a look whether it is running at a lower priority.
    Edited again: and are you sure it's not running with some compatibility mode set by Windows?
    Somebody had a problem with DazStudio being slooooow and found out his desktop icon somehow was set to Vista compatibility ... for whatever reason.
    Post edited by Kerya on
