Digital Art Zone
A Shadowy Proposition
Posted: 11 July 2012 03:08 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-06-18
So I like to tinker and experiment with things that can be done in Studio raspberry
Earlier today I was uninspired, board or maybe just feeling lazy, but I had a thought.  surprised excaim
“can something that is not there render a shadow?” My first thought was no, but then, why not?
I started thinking and had an idea. So when I got home from work I set up a simple scene in Studio and tried my idea, and guess what, it worked.  big surprise
It was to easy I thought, so I created a scene inspired by a magicians act. The result is the first render below.
In the second image I decided to have a little fun ala Peter Pan.
These are 100 % rendered in Studio using 3Delight with NO postwork.
Now I’m sure some of the veteran Studio gurus can figure out exactly how I did this in a heart beat, so I put it to all of you to see if you know what I did to get this effect.
Post your solutions, include a render if you like, start a discussion amongst yourselves, after all this is the Discussion forum. I would really be interested in how you would achieve this effect or if you can figure out how I did it.
I’ll tell all sometime this weekend. Until then let’s see what you’ve got.  cool smirk
Image Attachments
Profile
Posted: 11 July 2012 04:08 AM   [ Ignore ]   [ # 1 ]
Power Member
RankRankRank
Joined  2004-07-01
to easy
Profile
Posted: 11 July 2012 05:05 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2005-11-10
I wont give it away but we have been able to do this for quite a while (I did this image in 2007 created in DS no post work)
Image Attachments
 Signature
Community Volunteer:
My DAZ Store
NeilV Poser Stuff & Chohole’s Space
Old Post Count = 6362
Profile
Posted: 11 July 2012 05:47 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2010-06-18
Oooh… I really like this image NeilV… yea I knew that those who have been doing this for far longer than I would know how right away…
For me half the fun is in finding and figuring out how to do these sorts of things. This started with a thought and I worked it out… if I had seen your image, I would have sat myself down and toyed around until I got it.
My hope is to maybe inspire a few others who haven’t learned this simple trick to also play around and have some fun with it.
Thanks for sharing… smile
Profile
Posted: 11 July 2012 06:13 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I, of course, don’t use DS, but have done similar things in Bryce.
Another thing I also like playing around with is reflections of things that aren’t there, can do some real spooky effects with them as well.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 11 July 2012 07:24 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
One of the more interesting things you can do in DS is negative lighting.  Double click on a light’s “Intensity” setting and remove the Use Limits checkbox, set the light to a negative intensity and see what happens. smile
 Signature
My Tutorials and Freebies Index
Profile
Posted: 11 July 2012 10:53 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2005-11-10
niccipb - 11 July 2012 05:47 AM
yep its lots of fun to play around with these things yourself and see what you are able to came up with.
 Signature
My DAZ Store
Profile
Posted: 11 July 2012 03:51 PM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  0
There was a thread on the old forum on how to make a shader that don’t generate a shadow and/or reflection. You could use the same setup to turn of visibility but keep the shadow too.
The cylinder is one object with two materials.
Image Attachments
Profile
Posted: 24 July 2012 03:03 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
Well, how did you do it?  Fantom on Ubersurface?
Profile
Posted: 24 July 2012 05:11 AM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2012-02-21
Would you provide your secrets, I’m really curious.
Profile
