Digital Art Zone
1 of 2
1
trees, trees, trees…..
Posted: 10 July 2012 03:54 PM   [ Ignore ]
Member
Rank
Joined  2003-11-09
i’ve been trying out the abaro program and it makes some really nice trees—unfortunately they’re really nice BIG trees with about a gazillion polys that take the better part of a week to render.
short of a new computer, are there any tricks to reducing the polys or somehow compressing the obj for some semi-decent render times in Bryce??
TIA.
:8
 Signature
Profile
Posted: 10 July 2012 04:39 PM   [ Ignore ]   [ # 1 ]
Power Member
RankRankRank
Joined  2011-11-16
I haven’t used Bryce in years but I believe there is an instancing feature?
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 10 July 2012 09:04 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2005-09-28
Afraid not. Poly reduction isn’t in Bryce’s arsenal.
Bryce’s native tree lab is generally cheap on polys.
 Signature
Oroboros Presents… KEY-FLAME: Bryce Animation Tutorials
Profile
Posted: 11 July 2012 02:31 AM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2003-11-09
just thought i’d ask.. it makes trees so much better than the tree lab does!
8}
 Signature
Profile
Posted: 11 July 2012 06:08 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Hexagon has a decimate functioin that works quite well which I have had to use before so I could load a prop into Bryce.  That should help reduce the poly count whist keeping its shape.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 11 July 2012 08:36 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
You can play around with Bryce trees
Good looking Trees
On-line: http://www.horo.ch/raytracing/tuts/online/tut20/minitut20_en.html
PDF: http://www.horo.ch/raytracing/tuts/pdf/minitut20_en.pdf
I also like combining several trees to make one tree, as Bryce trees do render much easier than imported trees.
Image Attachments
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 11 July 2012 12:07 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2003-10-09
Just wondering if it might be the leaf texture that’s causing the excessive render times- do the leafs use any transparency? If it does try going into the Render Options and turn down the Maximum Ray Depth until you start getting artifacts. Getting it down from the default of 6 to 5 or 4 can make a big difference in render times.
If it’s all geometry, one other thing you might try is to load it into a modeler and remove all the polygons on what will be the “back” of the tree since that won’t be seen in the render anyway. This is a very old Bryce 4 image using this technique (TreePro trees btw) - if you look closely you can see the backs are gone but I was able to cut poly use by around 40%.
Image Attachments
Profile
Posted: 11 July 2012 01:40 PM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
You should post more of your artwork, Dan. An excellent Bryce 4 render!
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 11 July 2012 01:52 PM   [ Ignore ]   [ # 8 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Love the Dragon fly, which one is that ?
 Signature
Profile
Posted: 11 July 2012 03:30 PM   [ Ignore ]   [ # 9 ]
Member
Avatar
Rank
Joined  2003-10-09
Horo - 11 July 2012 01:40 PM
I agree. He reached a critical threshold with this one. ;- )
Profile
Posted: 11 July 2012 08:50 PM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2003-11-09
some really great ideas here… decimating in Hex and stripping out polys from the back are two things i *should* have thought of and didn’t—things i’ve done before in other situations….  i guess I just needed a group brain push….
@horo - if you’re still reading this, i noticed in your tute that you had an arboro tree in a scene—do you do anything special with them or just put up with the render times?
and yes, i did add some transparency to the leaves which would be contributing factor to the long render times….  (i didn not adjust the ray depth)
@cohole -  that’s a great idea about combining trees… that’s one of the problems i have the the tree lab, is that the trunks are genrally too narro for a mature tree, and if you keep running up the trunk size, you end up with logs for stems in the upper tree—looks like a ball of timbers.
thanks all for you input!
:8
 Signature
Profile
Posted: 12 July 2012 12:32 AM   [ Ignore ]   [ # 11 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
Oh, I just experimented with different tree programs (Arbaro, Dryad, Ivy Generator, Plant Studio, Carrara, ...). Bryce trees are not bad, but could be improved (there was some improvement from 6.3 to 7.1: the typical Bryce bulge in the trunk is less obvious). The good thing about Bryce trees is that they are low poly count. I think the real vegatation guru visiting these forums is Rashad.
 Signature
Profile
Posted: 12 July 2012 03:16 PM   [ Ignore ]   [ # 12 ]
Member
Rank
Joined  2003-11-09
i would agree that Rashid is quite the greensman—but it seems that he’s not come across this topic yet…
 Signature
Profile
Posted: 13 July 2012 06:14 AM   [ Ignore ]   [ # 13 ]
Member
Avatar
Rank
Joined  2003-10-09
Thanks so much for the comments on the image, it’s appreciated!
Chohole - I modeled the Dragonfly in FormZ. I never did post it because (at the time) it was much to big in size. I’ll try to dig it out (if I can find an Iomega USB disk drive, mine are all SCSI).
Profile
Posted: 13 July 2012 06:34 AM   [ Ignore ]   [ # 14 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
dan whiteside - 13 July 2012 06:14 AM
Ye dogz, an Iomega disc drive. If that is the same as one I had back in the day, I left it behind when moving along with all the other stuff a charity was going to clear and sift through, as we were vastly downsizing when we moved.
 Signature
Profile
Posted: 13 July 2012 08:17 AM   [ Ignore ]   [ # 15 ]
Member
Avatar
Rank
Joined  2008-03-28
hiker_1 - 10 July 2012 03:54 PM
TIA.
:8
Hello hiker_1
Really nice trees regardless of which program they are made in [Bryce can make some nice trees too but it is a bit of work to accomplish this] are always going to be BIG. The ONLY Home PC program i know off which can import and render a large conifer with 100 million polygons [all those needles] and render it to perfection with volumetric shadows [so-called “God Rays”] in less than an hour, is 64-bit Cinema4D with at least 8GB of RAM!!! [ http://www.maxon.net/de/downloads/demo-version.html ]
I would not recommend importing large trees into Bryce! Sorry! I have done it. I have loaded a nice large Tree from Carrara 6.1 just now. Well i managed to get it into Bryce, but it took a long time to import and it was a lot of messing around in Carrara to be able to make it and export it. See picture below. [85,826 K file size]. And that’s NOT really a “LARGE” tree in my experience!
But i suppose this tree, made in Carrara 6.1, looks nice but i have not had time to put Bryce materials on it [ but you can make something just as nice in Bryce - look at the vegetation work Rashad Carter has done in Bryce ].
I really would suggest you learn how to make nice Trees in Bryce. Compressing the mesh of an OBJ file Tree is a very complicated business [you can’t just decimate it]. You can do things in Lightwave3D or Cinema4D to that end. But either of those 2 programs is expensive to purchase.
Well i am sure you have lots of good advice.
Kind regards
Peter
Image Attachments
Profile
1 of 2
1
