I’m looking forward to this great tool and I hope (like all the others here) that you will release it soon (in the closest meaning of this word).
Maybe you remember that I’ve requested a British Guardian Bear fur Hat, as you’ved released “Ursus Arctos” and I was totally impresed from the realistic fur (which was a sensation at the time of the release, that was unfortunately not as appreciated as it deserved it.
Could i now just add a simple geometric cylinder on M5’s hat and add your “hair” to this cylinder to create this kind of Guard Hat????
Hi Spanky, I remember about that Bear fur hat: that would be very easy to accomplish. As you suggested, I added a simple cylindric shape, made the guide hair, used the spherize effect and done. Maybe a little combing or frizz effects would produce a better shape, but you get the idea… it’s possible to fur any kind of object…
About the hat again, I had your message saved in the PM box here, and by mistake I deleted all the content and could not remember your nickname, so I could not come back to you. Sorry about that.
I’ve been trying to look at the capabilities and I think you mentioned something about a feature that would allow you to draw the ends of the hairs together to form spiky hair or taper it like wet fur or hair is tapered together.
think it was on the old forum but is there a way you could demonstrate that?
That feature you probably refer to as “clumping” has been removed as is no longer possible to manually edit full hair. I have another solution under development to achieve the same effect, but nothing to show yet. Sorry.
Any ideas on when Yet? 6 months? 4 months… less. I’m gonna be happy no matter when, I’m just really wanting this.
The plugin is basically ready, meaning that all the features in beta 1.3 (yet to be delivered to testers) are operative and working reasonably well.
With the beta test team we need to address eventual bugs and issues, and test it well enough until it can be declared stable.
Also, I’d like to see testers achieve enough practice with it and see some nice models and images produced with the plugin.
Can’t say anything precise, but I believe at most in two months it should be finally ready. Of course even earlier if testing will run faster than expected.
