Digital Art Zone
90 of 100
90
Look at my Hair: official thread [Commercial] RELEASED!
Posted: 30 December 2012 08:40 AM   [ Ignore ]   [ # 1336 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
The eyes, whether for the transparency on the lashes or the reflective settings on the eyes themselves, often cause a pause in the render progress for me - are you sure what you are seeing is down to LAMH?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 30 December 2012 08:44 AM   [ Ignore ]   [ # 1337 ]
Member
Rank
Joined  2011-02-16
Sorry I am not being clear - Yes I have been using the snipping tool and have been enlarged and reduced the size of the brush, but I think I should do this before styling the hair and not after, because when they curl some I can never catch to snip, especially around the eyes and lashes. Yes the render pauses for a couple of minutes at the lashes - and I have seen it actually mention the lashes in the render dialogue box - and then it resumes, generally it is between 48-51% mark on a head shot.
I’ll zip up my lmh files and send it to see if you can see what I am doing wrong, Thanks.
 Signature
Meg
Michael 5 made me a convert to DS4
DS3A and DS4.5Pro on W7 64bit laptop and W7 32bit desktop
Profile
Posted: 30 December 2012 08:51 AM   [ Ignore ]   [ # 1338 ]
Member
Rank
Joined  2011-02-16
Sorry Richard - we cross posted. It is the base M5 character rendered with one or two lights in 3Delight and it doesn’t pause noticeably when I am not using LAMH. At first I thought I had left some red there - I did when painting and had hairs coming out the lips wink But I checked over that on the density map.
 Signature
Meg
Profile
Posted: 30 December 2012 08:52 AM   [ Ignore ]   [ # 1339 ]
Active Member
Avatar
RankRank
Joined  2009-10-27
3Ddreamer - 30 December 2012 08:44 AM
Well, the cutting (or scissors, or snipping) tool is meant to work anytime. When you say that it won’t work properly after they curl, you mean that after applying the curl effect (through the slider), cutting won’t work as supposed?
 Signature
Blog
FB
YT
Pinterest
Profile
Posted: 30 December 2012 09:13 AM   [ Ignore ]   [ # 1340 ]
Member
Rank
Joined  2011-02-16
I don’t think it is anything in LAMH, just my ability to use it wink I’m not having much success cutting guide hairs after I apply the deformers, I guess I am either accidently including the root node or something because some I can never cut no matter what I do
 Signature
Meg
Profile
Posted: 30 December 2012 11:07 AM   [ Ignore ]   [ # 1341 ]
Active Member
Avatar
RankRank
Joined  2009-10-27
3Ddreamer - 30 December 2012 09:13 AM
Hi, got your .lmh file!
I see your point, indeed cutting hair away from such tiny and small areas can be difficult. I’ll prepare a movie tonight to show a different and faster approach, using also density maps. See you soon… smile
 Signature
Blog
FB
YT
Pinterest
Profile
Posted: 30 December 2012 01:58 PM   [ Ignore ]   [ # 1342 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Shaaelia - 30 December 2012 12:32 AM
Hurray!  My first attempt with LAMH.  1hour 16 minutes to render.  The video tutorials were a great help.  Her expression is no indication of the plugin grin
That’s really nice. Love the color and the bangs. The ends look so, so, real!
Profile
Posted: 31 December 2012 12:02 AM   [ Ignore ]   [ # 1343 ]
Active Member
Avatar
RankRank
Joined  2007-12-04
Alessandro_AM - 30 December 2012 04:23 AM
This is a first attempt ? I’ll be VERY curious to see your next one! smile
Wow, thank you Alessandro :-D.  Thinking about the next scene at the moment… I have a few ideas in mind, just need to choose one grin
Spit - 30 December 2012 01:58 PM
Thanks Spit.  I was amazed when it rendered out, it looks so much finer than I was expecting.
 Signature
Follow me on facebook, check out my website or find my freebies here.
Don’t forget to have a look at The Wizard’s Library, my multi-figure Daz scene.
Profile
Posted: 31 December 2012 01:12 AM   [ Ignore ]   [ # 1344 ]
New Member
Joined  2012-12-24
Hi Alessandro
When I export using OBJs and use reality render to render, Lux gives missing error on a jpeg file.
[2012-12-31 01:03:49 Error2] Error hashing file <user directory>/Documents/DAZ 3D/StudiolookatmyhairAMgeometryGenesis_TMap_0.jpg'
[2012-12-31 01:03:49 Error: 3] Unable to open image file '
This is because the scene file contains following line
Texture "default_8.Kd" "color" "imagemap" "string filename" [" <user directory>/Documents/DAZ 3D/Studio\lookatmyhairAM\geometry\Genesis_TMap_0.jpg ...
I’m suspecting this is because the jpeg file was referred with backslash \  in the materials. While this may be a bug in the reality plugin, and has a work around by changing the reality scene file manually,  I was wondering if something can be also done in the next release of LAMH to avoid using directories. None of the other material textures have path in their name, instead they just have the file name.
Thanks
Profile
Posted: 31 December 2012 03:53 AM   [ Ignore ]   [ # 1345 ]
Active Member
Avatar
RankRank
Joined  2009-10-27
Hi hakcayurek, I’m forwarding this to Kendall so that we can take a better look at it. Some users reported that the .jpg generated by LAMH was somehow not readable by Lux (while it worked fine on other applications such as Vue, Octane, Keyshot etc.), and they had to open it in an external image editor and resave it, to make it work.
So we’ll definitely take a look, thanks for sending these details.
 Signature
Blog
FB
YT
Pinterest
Profile
Posted: 31 December 2012 05:08 AM   [ Ignore ]   [ # 1346 ]
Member
Rank
Joined  2011-02-16
Alessandro_AM - 30 December 2012 11:07 AM
Many thanks. I am sure it will get easier with practice grin
 Signature
Meg
Profile
Posted: 31 December 2012 06:05 AM   [ Ignore ]   [ # 1347 ]
Power Member
Avatar
RankRankRank
Joined  2007-11-30
I’m getting better results now. I think it’s because I didn’t export as OBJ and used the standard shader preset as made by Alex. The first time I exported as an OBJ was because the render stopped due to something after I exported as Renderman splines, and I wanted to see ‘anything’. Not sure why DS wouldn’t render, but it works perfectly fine now.
 Signature
Still not bald.
Profile
Posted: 31 December 2012 02:23 PM   [ Ignore ]   [ # 1348 ]
Active Member
Avatar
RankRank
Joined  2007-12-04
Playing again - everything from scratch this time.  It’s not perfect, but it is pigtails!
Image Attachments
 Signature
Profile
Posted: 31 December 2012 02:51 PM   [ Ignore ]   [ # 1349 ]
Member
Avatar
Rank
Joined  2007-03-03
OK, I apologize as I’m sure this has been asked, but is this dynamic hair?  How well does it animate?  Anyone have a link to a video?  I love the look of it in stills, but I’m also interested in its animation potential.
 Signature
-Kodiak3d
“I wonder what tomorrow has in mind for me, or am I even in its mind at all?”
- “Crystal Ball” by Styx
Profile
Posted: 31 December 2012 05:05 PM   [ Ignore ]   [ # 1350 ]
Member
Avatar
Rank
Joined  2005-01-08
Alessandro_AM - 31 December 2012 03:53 AM
hakcayurek - 31 December 2012 01:12 AM
Hi Alessandro
Thanks
Just stopped in to see what’s up.  The back slashes are the problem.  I have ran into this issue during my tests and found that editing or correcting these in Reality prior to sending to Lux fixes the problem.
Profile
90 of 100
90
