Digital Art Zone
9 of 100
9
Look at my Hair: official thread [Commercial] RELEASED!
Posted: 18 June 2012 02:38 PM   [ Ignore ]   [ # 121 ]
Addict
Avatar
RankRankRankRank
Joined  2003-12-06
On a related topic to exporting, what about saving? Does the LamH data save as part of a conventional scene file (or, with the new D|S4.5, a .duf file) — and, just as important, does it reappear with no differences when the scene is re-loaded? Or do we save a separate Renderman-compatible data file with the hair settings?
 Signature
Gone to Vegas to play poker. Back when I run out of clothes.—Your Muse.
Profile
Posted: 19 June 2012 07:27 AM   [ Ignore ]   [ # 122 ]
Power Member
Avatar
RankRankRank
Joined  2009-10-27
SpottedKitty - 18 June 2012 02:38 PM
The way it works now, LAMH saves all the follcles and hair in a file that you can load back and apply to the same figure or object it was designed for. Once the project is loaded, you’ll need to do the export again (exporting as RenderMan just take 2 seconds). Loading back the project means that the hair will be there just as they where saved.
I’d like also to add the possibility to save a scene which contains RenderMan objects, or an object itself as .dsu or .dfu; however, I’ll wait for the 4.5 SDK to be final. I had troubles using the save to .dsf/.dsu functions and I believe there is a bug somewhere in the SDK.
 Signature
Alessandro’s Store
Blog
LAMH FB
Profile
Posted: 19 June 2012 09:50 AM   [ Ignore ]   [ # 123 ]
Power Member
Avatar
RankRankRank
Joined  2009-10-27
As from the blog: “Mandrill
A mandrill, created out of the Genesis Gorilla. Exported the head and neck in ZBrush, morphed it, made a very basic texture and imported in LAMH. Created the hair, styled, rendered. Made some adjustments and a little bit of HDR toning in second image.
Hair are way too thick (visible especially near the mouth), anyway is a good result.”
Image Attachments
 Signature
Alessandro’s Store
Blog
LAMH FB
Profile
Posted: 22 June 2012 04:00 PM   [ Ignore ]   [ # 124 ]
Member
Avatar
Rank
Joined  2003-10-09
I just found this thread.  All I can say is Wow!!!  I can’t wait for this product.  The pictures are awesome.  Thank you for making such a great future product.
Profile
Posted: 23 June 2012 04:13 PM   [ Ignore ]   [ # 125 ]
Power Member
Avatar
RankRankRank
Joined  2009-10-27
Fay68 - 22 June 2012 04:00 PM
Thanks to you for following my project smile
 Signature
Alessandro’s Store
Blog
LAMH FB
Profile
Posted: 26 June 2012 02:18 PM   [ Ignore ]   [ # 126 ]
Member
Avatar
Rank
Joined  2006-08-24
Ditto every bit of that sentiment.  Started reading last night thanks to Matt following you and went through the entire forum thread, though I’ve not seen the videos yet.  Very exciting.
Regarding the taper, I had a thought that will probably need to be reserved for the next version if implemented.  I see that around the end of May you added a parameter to alter where the existing taper happens, but I can imagine a system for much more complex shapes, that would not need to be complex on the user’s end.  I don’t think the coding would be extreme, but I don’t know the code end.
I have several variations on the input that are floating around in my head as I type.  One could be a linear envelope chart that works like the curves tool in Photoshop.  (I think curves for deformers in Studio have a similar interface.)  Left end is the base and right end is the tip…user can define any number of points—they could directly tie to the segment count node if desired—and drag those points up or down to adjust the width of the hair at that point.  A few buttons for common default shapes would be handy.  This curve or point set would override the basic taper.
I could also see this being coded by hand as a simple list of points like one-dimensional UV coordinates or use a linear gradient image as an alpha map, but the above option would be very user friendly.
Having this kind of option would work well for grass, more varied types of hair and even for really strange shapes, like bread mold or industrial Velcro.  (New designs by 3M have both sides with pinhead-shaped nubs that interlock like a field of zippers.)  Grandma’s pincushion could be built procedurally, once one has the tomato-shaped base.
 Signature
        “I fight for the Elves.”
Profile
Posted: 30 June 2012 02:20 PM   [ Ignore ]   [ # 127 ]
Member
Rank
Joined  2008-05-14
Alessandro_AM - 19 June 2012 09:50 AM
This is awesome, lol! LOL
Profile
Posted: 05 July 2012 12:23 AM   [ Ignore ]   [ # 128 ]
Power Member
Avatar
RankRankRank
Joined  2010-03-01
So how is beta testing coming along? Do we have some pretty pictures?
Profile
Posted: 05 July 2012 05:21 AM   [ Ignore ]   [ # 129 ]
Power Member
Avatar
RankRankRank
Joined  2009-10-27
Dollygirl - 05 July 2012 12:23 AM
Not many renders so far, we are concentrating on spotting issues (and there are quite some). In a few days beta 2 should be released and hopefully with that testers will be able to produce some images.
 Signature
Alessandro’s Store
Blog
LAMH FB
Profile
Posted: 05 July 2012 05:28 AM   [ Ignore ]   [ # 130 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
This is a must have for me. Setting aside money to purchase as soon as it is released.
This may have been asked before. If it was I missed it. Will it be allowed for people to share hairs for figures that they have made?
 Signature
Exile, Drows Walk: A Tale of Jaderail starts here. Free pulp fiction at its Fantasy best, Updated 2/3/14.
Proud Member of the Bald Wizards Club My stuff at DeviantArt
Profile
Posted: 05 July 2012 05:39 AM   [ Ignore ]   [ # 131 ]
Power Member
Avatar
RankRankRank
Joined  2009-10-27
Jaderail - 05 July 2012 05:28 AM
Hi, projects can be saved and loaded back as .lmh files, so yes, you can share those with other users.
 Signature
Alessandro’s Store
Blog
LAMH FB
Profile
Posted: 05 July 2012 05:43 AM   [ Ignore ]   [ # 132 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Wonderful, now I’m even more excited. Code,Test, finish. Hurry!!
 Signature
Profile
Posted: 05 July 2012 05:58 AM   [ Ignore ]   [ # 133 ]
Power Member
Avatar
RankRankRank
Joined  2009-10-27
Jaderail - 05 July 2012 05:43 AM
I am, believe me! LOL
 Signature
Alessandro’s Store
Blog
LAMH FB
Profile
Posted: 05 July 2012 07:06 AM   [ Ignore ]   [ # 134 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Ok, I know we won’t have dynamic hair in this first version but will it be possible to lets say work with a Genesis V5 animation shape the hair in frame 1 and then shape it differently 10 frames after like doing a wind swept and have the software interpolate the changes inbetween like traditional frame to frame animation?
 Signature
Render with muscle! SimonWM DAZ Store.
For Previews and Insight SimonWM Official Facebook Page.
Artist Page My Gallery at Deviant Art.
For Videos My Youtube Channel.
Profile
Posted: 05 July 2012 09:20 AM   [ Ignore ]   [ # 135 ]
Power Member
Avatar
RankRankRank
Joined  2009-10-27
SimonWM - 05 July 2012 07:06 AM
Hi Simon, I’ve been thinking about it (i.e. interpolating hairs between frames) but it’s all to be done. I don’t think I’ll be able to code that for the initial release.
 Signature
Alessandro’s Store
Blog
LAMH FB
Profile
9 of 100
9
