Digital Art Zone
Leaves UV map
Posted: 10 July 2012 02:58 AM   [ Ignore ]
New Member
Joined  2010-07-15
Hello,
I am quiet new in this topic and found Bryce 7 pro very useful product. My question is how to export trees with UV maps of leaves ? I found many leaves texture in Bryce 7 Content but when I applied them to eg.: Apple Tree the leaves still remained as apple tree leaves, So is there any way to change the shapes of the leaves into a almost rectangular one that can be proper to apply leaf textures with UV ?
Profile
Posted: 10 July 2012 04:06 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
In the tree lab. Once you have a tree in your scene, click on the “E” which will take you to the Tree lab. At the top right you will see “Foliage” and under that “shape” click on shape and it gives you a drop down box. from the list click “User Leaf”  then down the bottom right use “Texture” and “image, click on edit and it takes you to the mat edit screen, where you can apply a leaf shape with matching alpha.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 10 July 2012 06:23 AM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Rashad Carter has covered this topic over at Bryce5.com - this should provide a direct link to one of his presets in the materials exchange.  There is information on the process involved in the description.  http://www.bryce5.com/details.php?image_id=2041
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 11 July 2012 04:14 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2010-07-15
Hello Guys,
Thanks for your quick and useful reply. This is great!
Profile
Posted: 21 April 2013 01:45 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
When selecting “user leaf”, what controls the transparency, if not the alpha image portion of my texture?  While flipping around and changing leave foliage shape and texture types I’m getting seemingly random results ranging from no transparency (my image on a square) to the wrong transparency (a different leaf’s transparency used with my image) to inverted transparency.
Profile
