how do I uninstall Urban Future, I can’t seem to find the uninstall file, I remember saying yes to creating the uninstall file.
Thanks again
I had the same problem with installed content, it happens when you install DAZ Studio on a different partition than C.
In my case i installed DAZ in D but the uninstallers goes to C .Same for render library for rendered images as default.
I can’t find or remember right now the folder with the uninstallers in XP (i didn’t installed items on DAZ 4 yet, i have some from DAZ 3 saved on another partition as archives since i reinstalled Windows on partition C, my Daz is still new no figures added, i worked with Bryce in the last time) but you might need to use the Search on your computer option.
Even if you don’t have the uninstaller there is a trick used by me :
Searching the file/folder names
1.Make a new folder , a fake one not a good one in Daz , then choose to install there a (same) product from Daz but without to check the uninstaller.
2.Go to that new folder and see the new files unpacked in/and the new folders.See the names so you’ll know what folders or files to delete.
3.Open your real Daz instalation folder and search for the same files/names and remove them.
(this is how i do when i install a small prop such as shoes, i don’t select the uninstallers because it fills the C partition, each uninstaller may have around 2 mb..imagine how many uninstallers or space on disk are created or occupied from 20 GB of content from daz..).Partition C drive is vital for the Windows and is recommended to be as much as clear and defragmented posible.
This is very useful for the poser content too, because lots of content creations from RuntimeDna or Renderosity or other websites, might not have installer with an uninstaller too, it keeps only a folder tree order which you should follow it when you add content without an installer.
If you have the uninstallers:
Searching the uninstallers
Try to search the name of the product with your windows search and see what you’ll find, usually the uninstallers should contain the same name as the main installer with the word “Uninstall” in front of the name.
if:Broken uninstallers/installations in Windows
There is an application which can help to remove any file or .exe or a broken installation including/tracking left over registry entries/keys.It’s called Revo Uninstaller Pro .If you need it, you may try it as trial if you can’t afford to buy or use to much.
Also see where are the default folders for scanning new content,render library,temporary work saved scenes in your DAZ settings if you need to move them to another partition on hard disk.
Oh and a tip how to install properly Daz Bridge to/in Photoshop CS5 or 6 is here http://www.youtube.com/watch?v=VJpRp6I52sQ
if you need .Read the last comments
Assuming your help needed is for daz not bryce, runtime folders are in daz not bryce, equivalent of the runtime is the presets folder in bryce.This is Bryce forum talk area
