Digital Art Zone
Stephanie 3 Petite Base questions
Posted: 09 July 2012 01:54 PM   [ Ignore ]
Active Member
RankRank
Joined  2009-11-22
I tried to install this item into different locations.
First I tried to install it into the DAZ content folder.
I also tried to install it into a Poser external runtime.
I got a message very much like this….. “The required content has not been found. Stephanie 3.0 Petite upgrade will now quit.”
This is not the exact wording, but very close. Is this an upgrade to a prior version of Stephanie, and do I need that?
What is going on, and what do I need to do?
Thanks very much.
R
Profile
Posted: 09 July 2012 02:55 PM   [ Ignore ]   [ # 1 ]
Addict
RankRankRankRank
Joined  2004-07-21
which product did you buy?  can you link to it?
 Signature
Hello, Sweetie!
Profile
Posted: 09 July 2012 03:07 PM   [ Ignore ]   [ # 2 ]
Active Member
RankRank
Joined  2009-11-22
Yes, here it is.
http://www.daz3d.com/shop/stephanie-3-0-petite-base-upgrade-from-stephanie/
Profile
Posted: 09 July 2012 03:11 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2007-08-20
What is the file name?
DAZ released 3 versions of Steph 3P.
There was the original release, the upgrade to the first release, and the final release.
Go to your DAZ downloads, reset and re-download a new copy of Steph 3P final.
This should solve your problem.
EDIT: cross post.
Yes, here it is.
That is the upgrade to the original Stephanie, and you must have it loaded first.
The one you want is.
http://www.daz3d.com/shop/stephanie-3-0-petite-base/
 Signature
My DeviantArt page
My freebies on ShareCG
Profile
Posted: 09 July 2012 03:21 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2003-12-06
There are actually two SP3 base products — the one you bought, which is an update from an earlier Victoria 1 vintage figure, and the standalone SP3 base, which is probably what you should have bought. No need to panic, you can get your money back with the DAZ 30-day refund offer. Although right now you might have a bit more than the usual couple of days wait, the support people are still neck-deep and clubbing alligators from the recent <ahem> somewhat less than successful store “update”.
 Signature
Gone to Vegas to play poker. Back when I run out of clothes.—Your Muse.
Profile
Posted: 09 July 2012 03:38 PM   [ Ignore ]   [ # 5 ]
Active Member
RankRank
Joined  2009-11-22
Thanks, Kitty and nitehawk.
That is a big disappointment. Now the price on Stephanie 3.0 Petite Base
you recommend is gone up to $27.00, way more than the sale price.
Hold on….Stephanie 3.0 Petite Base (Upgrade from Stephanie)... that I did buy, apparently is compatible with V3 and S3, according to the “Additional Information” section.
Does this mean it can be used with V3?
And what Stephanie is referred to here?
Thanks.
R
Profile
Posted: 09 July 2012 04:03 PM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
It shouldn’t say compatible with V3, that is wrong. It does state that it is an upgrade, and as has been said already, it is an upgrade from the original Stephanie figure,
The only compatibility the SP3 has with V3 is that they can use the same texture maps. They can’t use each other geometry.
Anything that says it is an upgrade will always need something to upgrade from.
If you don’t have the original Stephanie figure then this upgrade is useless for you, and unfortunately the only thing you can do is ask for a refund, expalining that you bought it in error.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 09 July 2012 04:15 PM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2003-12-06
Bendinggrass - 09 July 2012 03:38 PM
Something else that can bite you in the anatomy — the names of some figures are a bit inconsistent. In this case, S3 is SP3 is Stephanie Petite 3 (that last with or without the 3… at least until SP4 was released as a V4 morph). It’s confusing, I know, but we’ve been dealing with it for years and we’ve got used to it. You’ll soon figure it out.
 Signature
Profile
Posted: 09 July 2012 04:27 PM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2008-03-27
The original Stephanie is apparently no longer in the store, but she was the roughly the equivalent of Victoria 2. The image below shows what she looked like.
Oddly, the Stephanie Reduced Resolution Figure is still available, but you can’t upgrade from that.
Stephanie 3.0 Petite Base is $27.97 (Pt Club Price), but the upgrade you purchased is still only $6.95.
Image Attachments
Profile
Posted: 09 July 2012 04:31 PM   [ Ignore ]   [ # 9 ]
Active Member
RankRank
Joined  2009-11-22
Thanks for the help and clarification, everyone.
Randy
Profile
