problems to save
laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 228
HI!!! I have a curious problem: at the end of the render, the save, as psd in multipass, never happens: it stays at 100per cent, without saving... anyone has an idea??
    I don't have a solution for you, sorry.
    But as workaround, I would try saving multipass elements as "external". That will write extra files for each multipass element.
    You might also try rendering with the Batch Cue (Pro)...
    I have seen this before, but no idea what causes it...
  • PhilemoPhilemo Posts: 885
    If you exported to PSD version 3, you might try to export a version 7.
    OTOH, that kind of silent crash is often caused by a lack of memory. So Holly's suggestion to use batch mode is a good idea.
  • laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 228
    thank you!!! it was exactly that, the export in psd version 3... with 7 in option, everything works fine!!! thank you!!!
