Digital Art Zone
Selection disappearing when selecting sweep surface tool
Posted: 08 July 2012 07:35 PM   [ Ignore ]
New Member
Joined  2012-02-07
Hi everyone,
I’m having a problem with my surface selection deselecting itself when I click on the sweep surface tool.
I have a simple cube and select 2 opposite sides with the select faces tool. I then click the sweep surface tool and continue my modeling.
Then if I select more surfaces and then click the sweep surface tool again my selection deselects itself.
I’m not sure what’s going on here. I’m following a beginner video tutorial and they are able to this: http://www.geekatplay.com/tutorials/hexagon/one/
Any help would be greatly appreciated smile
I am using Hexagon 2.5.1.79 on Mac OS X 10.7.4.
Profile
Posted: 08 July 2012 08:18 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2005-08-20
Sorry, can’t replicate your issue.
 Signature
*Sigh* Window->Tabs->Tool Settings->Draw Style->Manipulation: Off
Yeah. It’s like that.
Profile
Posted: 08 July 2012 08:23 PM   [ Ignore ]   [ # 2 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Have you sought help here Hexagon Discussion Forum? All Hexagon users all the time. Just the people who might know the answer to your problem.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 08 July 2012 08:47 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2012-02-07
Ascania - 08 July 2012 08:18 PM
Yeah, it’s really weird. The tutorial I’m watching just works and mine doesn’t.
Thanks for testing it out though.
Cheers.
Profile
Posted: 08 July 2012 08:48 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2012-02-07
Jaderail - 08 July 2012 08:23 PM
Thanks for the forum tip. Sorry for posting to the wrong forum.
Cheers.
Profile
Posted: 08 July 2012 09:01 PM   [ Ignore ]   [ # 5 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
No apology needed you did just right. I just pointed you to the people with the most experience.
 Signature
Profile
Posted: 08 July 2012 10:31 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2006-08-23
That didn’t happen to me when I just tried it. What all did you do between your final sweep and selecting the new faces? I can only think it has something to do between those steps. I find modeling in symmetry distracting and don’t work that way so it’s very possible I’m doing something different than you trying to recreate your issue.
Just for the record, because I don’t model in symmetry, I also don’t use the sweep or extrude tools. After selecting the faces/edges I want to extrude I simply hold the ctrl key and use the widget. No need for validating anything and I get don’t loose any functionality other than symmetry.
Profile
Posted: 09 July 2012 04:19 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Threads merged and repeat of the question has been removed.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 09 July 2012 09:14 AM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2006-02-03
Stimpski - 08 July 2012 07:35 PM
Hi everyone,
Did you hit “return” or click “validate” or “double click” after extruding?
Also, if you want to extrude more than one surface, you must hold down the “Shift’ key to select all of the surfaces before selecting the “extrude” tool.
Profile
