Digital Art Zone
My old Daz Studio content isn’t loading into Daz.
Posted: 08 July 2012 11:07 AM   [ Ignore ]
New Member
Joined  2007-09-21
Recently installed Daz Studio 4.5 after not using Daz for months.
After installing the new program, I began the process of re-installing all of my old Daz .exe’s (hair, clothes etc.). The problem is, none of it shows up in the program.
After reading up on CMS, meta data etc. this is about all I could get the studio to do (see attached pictures).
It hangs on that “import content page” forever (arrow and hour glass), and never loads anything beyond the files you see listed there.
^^ I had attempted to do this: http://ca1-webvirt-forumweb.daz3d.com/viewtopic.php?p=3374278&sid=176c32a08518b4e55a1375bd10259583
^^ thinking it would work, but again nothing I’ve installed aside from the new Vicky 5 ponytail loads.
I have added the content database (c/program files (86) etc.) where my old files are to the content manager (see picture).
I followed this tutorial, thinking it might work:
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/packaging/tutorials/adding_metadata/start
^^ But I can only access the relevant folders via the content library - the files never show up.
If anyone has any advice it would be appreciated it. grin
Image Attachments
Profile
Posted: 08 July 2012 11:16 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
Did you tell Studio where the poser format content is as well?
Profile
Posted: 08 July 2012 11:58 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2007-09-21
No. I’ll dry that and see if it makes a difference.
Profile
Posted: 08 July 2012 12:25 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
A lot of the content will probably be in Poser format, so would appear under Poser formats in your second screenshot. In general it’s a bad idea to have content in program Files, and your location looks even odder as you have the Runtime folder selected (usually the folder selected would be the one that holds the Runtime folder).
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 08 July 2012 12:35 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2007-09-21
Didn’t work (including the poser directory). :-(
Profile
Posted: 08 July 2012 12:36 PM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
May be a bad idea, but that is how mine old one is set up because that was the default studio 2 location.
Profile
Posted: 08 July 2012 12:37 PM   [ Ignore ]   [ # 6 ]
New Member
Joined  2007-09-21
Richard Haseltine - 08 July 2012 12:25 PM
I was installing to program files because that’s where the installer was sending it.
I’m just going to clean-install everything and see if that works. grin
Profile
Posted: 08 July 2012 12:48 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Most old content does not have MetaData, only items with metadata will show in the Smart Content Tab. Open your Content Library Tab and look in it for your older content. If your Content Directories are set up properly you should find all your items.
Edit: And Richard is correct, all content should go into the proper content folder. My Library if you are reinstalling your items.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
