Digital Art Zone
SKYS NOT the limit! SKYS okay SKY!
Posted: 08 July 2012 08:13 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-09-22
How can I get rid of that thin blue line way off in the distance when using SKY or Realistic Sky?
I have UN-ENABLED GROUND and set the HORIZON at MINUS 50 INCHES BUT still have that annoying line on the horizion!!!
Profile
Posted: 08 July 2012 08:36 AM   [ Ignore ]   [ # 1 ]
Addict
RankRankRankRank
Joined  2004-07-21
Water Skis or winter skis?
Okay this is in the Carrara forum so this must be about carrara.  (I found this topic by view new posts)
Which version of Carrara?  I have some version of Carrara 8.  Do not think it is the latest version.  I am not seeing anything about Ski (water skiing or winter skiing either)
edit: I have Carrara but I am not too familiar with it, sorry.
 Signature
Hello, Sweetie!
Profile
Posted: 08 July 2012 08:52 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
GESS I meant SKYS!
Profile
Posted: 08 July 2012 09:19 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
The Skie’s the limit as far as the horizon line goes. If you want to use the RSE, you’ll have to change your camera angle or hide the horizon. There’s a couple ways to do this. You could use physical objects such as clouds or terrains, or you could use the RSE in conjunction with the background function under scene effects. Of course, you could skip the RSE and use the backround entirely. I know you’ve mentioned Photoshop before, you could use it to generate a large gradient image and use that as a background.
These samples show before and after. I used the RSE in conjunction with the Gradient Color function as a background for the after images.
Image Attachments
Profile
Posted: 08 July 2012 11:16 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
OH WOW! Thats great THANKS!
Profile
Posted: 08 July 2012 12:46 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2006-02-03
Can also add an infinite plain to hide the line.  Default placement hides the horizon line.
In this case I gave the infinite plain the same shader as the terrain.
Image Attachments
Profile
