Digital Art Zone
custom working plane
Posted: 08 July 2012 05:30 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2007-06-17
You would think I would know this but I don’t.
All these years of working with Hexagon and I have never used a custom working plane.
Can someone give me a practical scenario where I would want or need to use a custom working plane?
I am sure it will be ahhh-haaa moment.
 Signature
My Video Tutorials on Youtube
http://www.youtube.com/user/johnnybevo?feature=mhee
Profile
Posted: 08 July 2012 11:18 AM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2006-02-03
It’s mostly a CAD thing.
For instance you are working on a complex space ship and want to add a cargo door to a rounded hull.
You would make a working plane that fixes on the hull so that any modifications would be perpindicular to the hull even though the hull is round in shape.
Think of it as a magnetic “Rubic’s Cube” that allows one to keep things perpindicular to the object they are working on in object mode only.
(X,Y) (X,Z) (Z,Y)  It will allow one to zero out one of the X,Y,Z axis so that the plane can be used to precisely align you work in two axis only.
Symmetry works this way - sort of.
It’s also why robotic controlled arms can work at weird angles on parts.  They use custom working plane geometry to keep two axis control so that the object is always aligned in object space rather than world space.
I’ve never used this in Hexagon, don’t know where it located or how it is used. heh
Here’s an autocad tutorial that demonstrates one use.
http://www.youtube.com/watch?v=0K-2ntUYJsw
Profile
Posted: 08 July 2012 02:01 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2007-06-17
Design Acrobat - 08 July 2012 11:18 AM
I did figure out how to use it in a practical application. Now I will have to not forget about it and make the most use of it.
I will take a look at the link you posted.
Maybe an under utilized feature. When I get the ins and outs of using it I will post a video.
 Signature
Profile
Posted: 08 July 2012 04:28 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2009-09-16
johnnybevo - 08 July 2012 05:30 AM
A common scenario for me is the wing of aircraft. It has dihedral. If I set the custom workplane to the angle of the dihedral, I can then scale and move the vertices on my wing a lot easier to keep the tapering airfoil shape.
Profile
