changing size of render? Where?
KharmaKharma Posts: 2,429
edited December 1969 in Bryce Discussion
Where do I find the options to change the final render size?
  • TjebTjeb Posts: 504
    edited February 2014
    Post edited by Tjeb on
  • ChoholeChohole Posts: 27,772
    Very top left of screen. File / Document Resolution
    Post edited by Chohole on
  • KharmaKharma Posts: 2,429
    thanks chohole, I did find it but said file/document settings on my screen. I assume you need to set this before you start a scene, as I changed it on the scene I had already done and then rendered and only part of the scene was in the render.
    No, I always compose my images on a working panel that I can see the whole of, and then change the doc res to what I want the finished image to be, but in the same ratio. Once the render has finished you can use the little hand (bottom right) to move around the render, and you will see that it has all rendered.
    oh ok, thanks chohole :)
