Digital Art Zone
Can You Make A Multi Part Prop In DS4.0 Without Rigging?
Posted: 07 July 2012 12:39 PM   [ Ignore ]
Member
Avatar
Rank
Joined  0
I am working on a lamp prop with no moving parts. I want to be able to control what parts of the lamp that cast shadow. As it is not possible to to control shadow with the default material and I don’t want to use special shaders, the “Cast Shadows” button in the Display menu of the Parameter tab would be a good option. But then the prop has to be split up in several parts so you can select them in the Scene tab. Making a separate dsf for each part seems a bit sloppy and having to rig a rigid object like a sever overkill. Any options?
Cheers! Oom
Image Attachments
Profile
Posted: 07 July 2012 01:41 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Well, if it isn’t meant to be posable just lock all the transforms (set respect limits to on, and set the min and max values to 0) and ignore the weight maps and joint cnetres, other than the origin of the whole item, entirely
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 07 July 2012 03:15 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  0
It is a long list of extra steps to add functions and then disable them. I even had to make it TriAx weight mapped to be allowed to save it. Why do DAZ hate simple props?
Profile
Posted: 08 July 2012 02:28 AM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  0
After finally making a figure out of the lamp it turns out it did not do what I want it to. The figures Cast Shadow is only controlled by the root, the button is there for each part but it do nothing, If that is a feature or a bug is a bit hard to tell, the Visible in Render button works for each part so I am leaning towards the bug side.
Well, I’m back at square one.
It looks like it is impossible to do this in DS unless I take that hideous detour of poor fix for bad design and save the lamp as a scene sick
Any one with better suggestions or do I have to track down a friendly Poser user to create a pp2 for me?
Cheers! Oom
Profile
Posted: 08 July 2012 02:38 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2010-06-18
Hi Oom…
Now I haven’t tried this myself, but I assume you want to make the lamp a DS prop, parent all of the sub-objects to a main object and then Save As > Support Asset > DSF Figure or Prop file.
I know you can do this with .pp2’s, just not sure with DSF prop, like I said, haven’t tried yet.  There’s also the OBJtoPP2 script for DS3, but I haven’t tried it in DS4 to see if it still works.
Hmm… don’t know if this was of any help or not… confused smile
Profile
Posted: 08 July 2012 03:13 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Try using Legacy/Parametric rigging and see if that enables the shadow option on individual bones - in a TriAx figure the mesh belongs to the root, though I would have expected the code that allows bone-visibility to work to have enabled bone-shadow casting options too.
 Signature
Profile
Posted: 08 July 2012 05:49 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
Ehm, just parent the primitives to one another. No need to make a figure at all.
Profile
Posted: 08 July 2012 10:37 AM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  0
niccipb - 08 July 2012 02:38 AM
Hi Oom…
That is exactly what I’m trying to do but you can not have props with several parts then it as to be a figure. No need to try, it will not work, at least not in DS4.0
OBJtoPP2 was one of the first things I tried. Unfortunately it will bake the parts to a single object in the pp2.
Well… Thanks for trying wink
Richard Haseltine - 08 July 2012 03:13 AM
Thanks for a good try but same old, same old. Visible in Render works for the bones, Cast Shadow dose not.
I agree, as the button is there you would expect it to work.
ReDave - 08 July 2012 05:49 AM
For my personal use that will work fine but I was planing to release the lamp as a freebie. Releasing the lamp as three separate parts would make it look like I was totally clueless, no need to spell it out to people grin
Thank You all for the answers! More suggestions are welcome!
Cheers! Oom
Profile
Posted: 08 July 2012 12:38 PM   [ Ignore ]   [ # 8 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I’d make a bug report/feature request to have the sahdow setting work for bones- not that it helps you now, of course.
 Signature
Profile
Posted: 09 July 2012 01:31 AM   [ Ignore ]   [ # 9 ]
Member
Avatar
Rank
Joined  0
Richard Haseltine - 08 July 2012 12:38 PM
How? There used to be a sticker or announcement on reporting bugs, I can’t find it.
Profile
Posted: 09 July 2012 05:26 AM   [ Ignore ]   [ # 10 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Make a bug report (requires a separate account if you haven’t yet set it up) and select Feature under Severity.
 Signature
Profile
Posted: 09 July 2012 07:48 AM   [ Ignore ]   [ # 11 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
bugs.daz3d.com is the Bug Tracker
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
