Digital Art Zone
weapon in hand ?
Posted: 06 July 2012 01:54 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2006-05-12
hi
is there a solution to put some weapons directly in the hand of the characther
because for some products it doesn’t work and i ‘ve done it by myself
i think about adariel for v5 or heracles ... when i click on the weapon it appears on the feet ...
i use ds 4.0.3.47
thanks a lot
Profile
Posted: 06 July 2012 03:42 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
What you might try is parenting the item to the hand with Parent in place off - if you use the Change Parent dialogue it’s a check-box at the bottom. That way the item’s origin will align with the hand’s, you will need to adjust but as long as it was modelled square on that should be relatively easy if you go to Tool settings and change the axis setting to Use Local Coordinates or Use Object Coordinates
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 07 July 2012 07:44 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2006-05-12
Richard Haseltine - 06 July 2012 03:42 PM
thanks a lot richard i will try
Profile
