ManStan - 06 July 2012 02:23 PM
Not sure that is actually possible. Not with out reinstalling your OS.
You think I’m kidding?
It can actually be done but it takes some searching to get it all. Not sure about a mac but on a PC you uninstall all you can with the uninstallers then go folder hunting. Search your HDD for “DAZ” and you still may not get it all. Studio is one of the hardest apps I have found to do a clean reinstall of.
It is possible to remove DS4 without reinstalling OSX. If you use other DAZ programs, you don’t want to just delete every folder labeled DAZ.
I just flushed DS4P off my system a few days ago. The thing to remember is that DS4 scatters parts of the program into the Applications folder, the Frameworks folder, and the User folder (where it belongs) and into your root Library (where it doesn’t belong) - so CMS can always be running in Ring 0, taking up ram, virtual memory (2.5GB on my system), and stealing cpu cycles, regardless of whether or not you are running DS4.
To chuck the CMS, Go into your Library Folder on your boot drive. Drag the DAZ folder to the trashcan. Restart your computer - delete the DAZ folders from you trashcan - restart the computer.
That should remove everything.
