Wonderous Wares - Realistic Glass Containers for Carrara and DS Coming Soon (Commercial)
DimensionTheoryDimensionTheory Posts: 428
Here's a project that I've been working on for a while now, along side AgeOfArmour. Our goal was to bring you a large assortment of the most realistic, raytraced glassware for you guys to add to your renders. A total of forty different glass containers, each with their own textures and materials. These aren't just your ordinary container props though... Great care was taken to create the best, most realistic glass containers and liquid fillings possible. Raytraced reflections and refraction, glass thickness and separate liquid meshes make for physically accurate rendering!
Daz Studio Version:
* Forty glass container props with separate liquid materials for mixing
* Accurate shaders made using UberSurface for great effects
* Included example scene and lighting setup with skydome for drag and drop results
Carrara Version:
* Forty Carrara formatted glass containers built originally for Carrara's renderer
* Clever mapping and shader utilization mean completely unique materials
* Pre-built scene ready for loading and rendering, complete with caustics
500 x 650 - 101K
500 x 650 - 101K
500 x 650 - 104K
«1
  • DimensionTheoryDimensionTheory Posts: 428
    Here are some DS renders from AgeOfArmour...
    500 x 650 - 109K
    500 x 650 - 105K
    500 x 650 - 102K
  • MattymanxMattymanx Posts: 5,122
    Those look awsome DT!!! :D
  • scorpioscorpio Posts: 5,389
    Very nice I can never get glass to look right.
  • KhoryKhory Posts: 3,846
    Those look amazing!
  • NeilV_1NeilV_1 Posts: 442
    very nice DT glad to see you have still been working on these :coolsmile:
  • ColdrakeColdrake Posts: 227
    Wow, these look amazing! Excellent work.
    Coldrake
  • DoctorJellybeanDoctorJellybean Posts: 2,096
    I want it!
  • Digital Lite DesignDigital Lite Design Posts: 718
    These look fantastic! Can't wait to spend my money. :)
  • Fille123Fille123 Posts: 0
    Oooh great job! :-)
  • JohnDelaquioxJohnDelaquiox Posts: 1,130
    sooooooooo pretty
  • LoaarLoaar Posts: 0
    Looks great.
  • sazzyazzcasazzyazzca Posts: 57
    These look very nice! They'll be going in the cart as soon as I see them in the store.
  • JOdelJOdel Posts: 3,830
    So are the spills in the last image also props, or postwork?
    The spills and splashes are props that I believe use the liquid materials included in the DS version, but the props themselves are not included. AoA can tell you more :)
    Where does the red wine bottle and glass come from (2nd last image)?
  • HeatherleeaHeatherleea Posts: 247
    Wow, these are definitely going straight into the cart when they hit the store.
    Those are both included in this set.
    Thanks to everyone for the great comments! I'm hoping to get these out as soon as possible :)
  • Miss BMiss B Posts: 3,068
    Gorgeous DT, absolutely Gorgeous!!! :-)
  • th3Digitth3Digit Posts: 16,354
    there are splash props on sharecg, also one could whip some up using metaballs in Carrara and export as obj, not me, my sense of realism not that great, seen some good ones, maybe DT or AoA could whip up a bonus freebie for buyers of the set!
    I ofcourse will just use particles in Carrara but they don't export!
    Casual has DS metaballs!
  • Age of ArmourAge of Armour Posts: 426
    edited May 2012
    Thanks for the encouraging comments everyone!
    The image with the splash was originally just a fun little test of the containers under some different sky domes and I got carried away. I did some metaball particle simulations in Carrara which looked pretty good but, as Wendy pointed out, they couldn't be exported as an object.
    In the end I ran a low quality fluid sim in Blender then touched up the splash objects in Sculptis and Wings3d. The render was done in DS4 with one of the included liquid shaders applied to the splashes. If I recall correctly the only light in the scene is the default DS Camera headlamp. 99% of the work is done by the objects reflecting and refracting the skydome surrounding them. I believe the only post work was adding the "Rendered in DAZ Stuido" label.
    Thanks again. I hope everyone enjoys the containers.
    Post edited by Age of Armour on
  • SkirikiSkiriki Posts: 4,923
    Do want. Do want right now.
    Well, they look great. You might want to make a note on the product page that they *need* a skydome though. Otherwise there will be much wailing and gnashing of teeth and spinning of wheels until the word gets out.
    ...Boing, Boing, Boing... ;-)
    Any news? New renders, ETA, something? %-P
    These were actually out of my hands when I posted the thread lol, I believe they should be released before long though. I'd imagine this week :)
  • LeanaLeana Posts: 2,759
    Those look absolutely awesome :)
  • larsmidnattlarsmidnatt Posts: 4,508
    So the water materials can be applied to other objects, which is nice. What about the glass materials?
    Here they are.
    The glass shaders aren't meant to apply to everything, they rely on textures that are UV driven and the UVs are specific to the containers.
  • LEI1LEI1 Posts: 0
    Product looks great! Just a couple of questions:
    Is it possible to change the fluid height inside the containers? IE: if you had a number of glasses in one scene and wanted to vary the levels for each one …
    Also I'm hearing that a skydome is necessary, I think I've used a sky dome maybe once :red: and only because it was an outdoor scene ... How will needing the skydome affect renders that are set in closed spaces?
