How to remove skin texture
So im trying to use the m4 converter thingy but i found out that i have to remove the M6 skin texture but i dont know how to and how come the genesis doesnt load with texture but the genesis 2 does?
Loading new textures will replace the old, or you can select the surfaces in the Surfaces pane and click the image selector (little square thumbnail next to the colour bar or strength slider) and set it to None.
Genesis loads grey because it hasn't had its sex set - if you load the Genesis Basic Male or Basic female they will have textures applied.
ok i did that and it became blank then i switch to m4 UV loader and then ctied to load an m4 mat and nothing happened
ok i got the m4 skin auto converter but when i try loading mat it say error occured please red log
Did you have the figure selected in the scene tab? I sometimes try to apply a texture when the figure is not selected and get a message like that.
