Digital Art Zone
1 of 3
1
A Challenge for David Brinnen.
Posted: 01 July 2012 02:31 PM   [ Ignore ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
We are looking for a simple, easy to replicate way of generating “Toon” shaders int the Bryce DTE. Using Bryce 5 of course. as both the people who are interested use B5 still.
So can you come up with an easy recipe for us.
Both of us have a habit of doing well in the particular challenge that we need these for, and I personally tend to think that this challenge was designed to make sure we didn’t have a chance. rolleyes  smile
Seriously is there any easy way to do this. If anyone would know it would have to be you.
Challenge is to produce a comic style render without postworking it.
nothing too fancy, mind because we have to have quite a few things in the render as well, so it needs to be quick and easy.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 01 July 2012 02:38 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
Oh, that’s an easy one - there are already tutorials (minitut_19) as well as on the Mentoring DVD. Here are three examples:
http://www.bryce5.com/details.php?image_id=4619
http://www.bryce5.com/details.php?image_id=3337
http://www.bryce5.com/details.php?image_id=3265
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 01 July 2012 02:51 PM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Horo pipped me to the post.  OK so yes, http://www.horo.ch/raytracing/tuts/online/tut19/minitut19_en.html also, even though you are not using Bryce 7 Pro, it may still be worth your while looking at the cel shading video tutorials on the DVD as many of the same concepts can be applied to Bryce 5.
If you run into a specific issue, you can always post me the source and I will modify the file accordingly.  I can see I have at least four versions of Bryce sat on my desktop.  So it is all possible - I just have to be careful I pick the right version…  It can be very confusing sometimes.
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 01 July 2012 03:01 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
CEL (contour enhanced lines) and Toon (cartoon) shading are often mixed up. In fact, that is what I usually do ... But both are quite alike but not completely similar. Both can be done in Bryce. Toon shading is easier (specularity is the secret) than true CEL shading (negative lights must be used). Here’s an attempt: http://www.bryce5.com/details.php?image_id=4621 the idea was hatching, but the contours are enhanced.
 Signature
Profile
Posted: 01 July 2012 03:15 PM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I actually need this more for the other person I mentioned, as hs I am a member of the team that runs the challenge, so actually only enter on occasion. He only uses B5, for the same reasons I do, and doesn’t have the DVD.
I will point him to the mini tut anyway, thanks.
We just like proving that Bryce can challenge the rest, and he does regularly place.  He has a character that features regularly, who I am sure would do well with toon shading as a comic render. I attach here a copy of one of his entries for the “Summer Fun and PIN UPS ” challenge.
Set up in DS rendered in B5   http://www.daz3d.com/index.php?&ACT=50&fid=41&aid=5050_DCzDws4wpm91J8le7TJ8&board_id=1
linked to rather than displayed, just beacuse someone wants to object.
For clarification the TOS states that
Images that may be considered sexually suggestive will be reviewed by the staff of this site as to its appropriateness for inclusion i
which is a slightly different thing to a tongue in cheek render which shows nothing of note.
 Signature
Profile
Posted: 01 July 2012 04:07 PM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Horo and David, my friend says thanks for the link to that tut. He will have a look at it
 Signature
Profile
Posted: 01 July 2012 04:29 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2003-11-30
Oh great…now I’m in trouble. I’m gonna get banned! *whine*
Profile
Posted: 01 July 2012 04:45 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
LOL Hi LG, glad to see you wander over here. You should visit the Bryce forum more often
 Signature
Profile
Posted: 02 July 2012 02:53 AM   [ Ignore ]   [ # 8 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
OK here’s the set up.  Default Bryce sky settings apply.
1 - good old Stanford Dragon, a Vicki, a Bryce sphere and an infinite plane - all selected.  Modify the materials.
2 - the key is to set the Specular Halo to fully white.
3 - ambient (global is set to grey as default) controls the appearance of the shadow regions and specular the lit area.  No diffusion needed.
4 - modified the ground plane alone to this.  Again no diffusion.
5 - This is a start then.  But even in Bryce 5 it’s possible to create a more exotic effect…
Image Attachments
 Signature
Profile
Posted: 02 July 2012 02:58 AM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Now to do something a little bit crafty…
1 - select the perspective camera.
2 - edit > copy matrix.
3 - create a radial light and edit it.
4 - no diffusion needed and set specular to maximum.
5 - use edit > paste matrix - this will put the light on top of the camera origin.
Image Attachments
 Signature
Profile
Posted: 02 July 2012 03:10 AM   [ Ignore ]   [ # 10 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
1 - create another radial light, use fully negative secularity and apply paste matrix to put that also on top of the camera.
2 - now set movement to object space.  This will mean the negative light - which should be still selected, can now move back and forth in line with the camera Z axis.
3 - move the negative light back a bit.
4 - gives this effect.
5 - then fine tune the positive light.
Image Attachments
 Signature
Profile
Posted: 02 July 2012 03:16 AM   [ Ignore ]   [ # 11 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
1 - using the preview window set the specular effect down to get the effect you want.
2 - the final result of this tweaking.  Although not as sophisticated as the effects possible in 7.1 pro, you can still achieve some outlining in 5 using negative lighting.
My offer still stands, if you get stuck, send me the source to modify.
3 - here’s were you set your light in Bryce 5 - controlling the specular effect through the material and turning off diffuse accordingly.  Though, anyone familiar with Bryce 5 would already know that, I include this for those that only know Bryce 7.1 pro but are curious how things were before.
Image Attachments
 Signature
Profile
Posted: 02 July 2012 04:58 AM   [ Ignore ]   [ # 12 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-30
chohole - 01 July 2012 03:15 PM
LOL!! Thanks, that pic made my day cool cheese
 Signature
[Join the little green box collection party!]
Ianz Place
Daz 3D Documentation
Daz 3D on YouTube
Daz 3D Forum Archive
Profile
Posted: 02 July 2012 05:30 AM   [ Ignore ]   [ # 13 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Glad you enjoyed it. It is not my image, but one done by Lord Ganthor, who was surprised and amused to see it in the Bryce forum.
Da Real Man has quite a fan club.  I forget how many renders he has appeared in so far.
David this is great, really must find some time to have a play.  Thankyou
 Signature
Profile
Posted: 02 July 2012 05:57 AM   [ Ignore ]   [ # 14 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-30
Thank you David for doing this, looks wonderful smile
 Signature
Ianz Place
Daz 3D on YouTube
Profile
Posted: 02 July 2012 06:05 AM   [ Ignore ]   [ # 15 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
You are welcome.  Quick question, is their any way to get at the other half a dozen or so mini-tutorials that I put on the old forum, or are those lost forever now?
 Signature
Profile
1 of 3
1
