JimmyC_2009 - 02 July 2012 11:34 AM
If you did not buy the advanced Dynamic Control as a seperate plugin, you will have to remove the ‘dot basic’ from the dzoptitexclothbasic.dll.basic in your plugins folder. If you did buy it, you will need to reinstall making sure that it goes into the correct plugins folder, and then you should have dzoptitexclothcontrol.dll in that folder.
You could do a search for the plugin dzoptitexclothcontrol.dll on your system in case it has been installed nto the wrong place, there is a 32 bit and a 64 bit version available, and each version should be in the zip file with the appropriate DS4P version.
If you look at my previous post, you will see what you have to do. When you install the paid for plugin, it renames the basic plugin as stated above, and you have to rename it for it to appear in the Window > Tabs area.
If you did not buy the plugin, then the one that comes as a seperate installer in the ZIP file is of no use to you. You need to purchase it to get the serial number. Rename the ‘basic’ plugin and it will work OK.
