Digital Art Zone
question about uninstalling DAZ
Posted: 30 June 2012 09:34 AM   [ Ignore ]
New Member
Joined  2012-04-16
Hi grin
I Think that I unfortunately have to reinstall Daz. The reason why is that went to the shop and bought the Snaggletooth Caverns. It comes in a zip file and that is ok, I have done zip files before in DAZ. But this time I did something wrong cause after I had unzip the file I put it all in my Library as it says in the PDFR help file for zip. But that must have been wrong cause usually the files is; runtime and read me files when it is unzipped,  but this time it starts with Poser and manifest.dsx. And if you hit the Poser file it comes with Bonus files, Props, Read me and Runtime. So when I was finish it all was wrong. Some was in DAZ studio Formats, but did not showed up, and some was in Poser Formats and did more or less showed up. So I have made that decision to reinstall it all. But it is all my fall I did it with some hangovers, unfortunately. So my question is; do I have to uninstall all my installed content first and then Daz or is it ok just to hit the uninstall button for DAZ and then all will be gone?
All the best
Hangover Peter
Profile
Posted: 30 June 2012 09:37 AM   [ Ignore ]   [ # 1 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
You only need to uninstall that one Item. Not DS or your other content. I do not have that as a Zip so I can not really be much more help.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 30 June 2012 09:56 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-04-16
HI Jaderail grin
Thanks for your answer. Yes it use to be like that, but there is not an uninstaller icon for the Snaggletooth Cave anywhere. I forgot to say that, sorry.
All the best
Peter
Profile
Posted: 30 June 2012 10:02 AM   [ Ignore ]   [ # 3 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
If you UnZip the file to a temp Folder you can look at the names and then deleate the same files from your My Library folder. Then Boot DS and have it Clean the removed items.
After that use your temp UnZip folder to look at all the files and where they go before you move them to My Library again.
I hope that helps.
 Signature
Profile
Posted: 30 June 2012 10:13 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2005-11-10
I have just reset my down load of this file and got the zip instead of the .exe
All the files look to be where they are meant to be just inside the content folder you have the Bonus folder which contains a scene file this can go any where (I normally keep mine in the runtime) the prop folder you see are the DAZ Studio versions of the props and would have had their own installer under the old system and then the runtime folder with all the Poser format stuff.
I am not sure why your Daz Studio items would not work as they look OK to me. I would just uninstall the one product and reinstall it no need to uninstall Daz Studio over one product.
 Signature
Community Volunteer:
My DAZ Store
NeilV Poser Stuff & Chohole’s Space
Old Post Count = 6362
Profile
Posted: 30 June 2012 10:44 AM   [ Ignore ]   [ # 5 ]
New Member
Joined  2012-04-16
@Hi Jaderail grin
Thanks for your answer. I will try that later in the evening after a visits on the couch, hoping that will remove my hangovers.
Thanks again
All the best
Peter
@Hi Neilv 1 grin
Thanks for your answer. If I understand you right you do not put it all in the library folder after un zipping but copy it one by one and then put it in the folders in DAZ? Did you got an uninstaller icon?
All the best
Peter
Profile
Posted: 30 June 2012 12:11 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2005-11-10
petvin - 30 June 2012 10:44 AM
@Hi Neilv 1 grin
All the best
Peter
no uninstaller icon so yep to uninstall you have to do it by hand.
and yep I tend to copy the folders over by hand in small chunks so do the props then the runtime the bonus folder is up to you ( I have my own location for scene files so I moved it to a different place). I am thinking that when we get the proper installer application to go with the zips which I presume is what the manifest.dsx that will take care of the uninstalling as well
 Signature
My DAZ Store
Profile
Posted: 30 June 2012 01:17 PM   [ Ignore ]   [ # 7 ]
New Member
Joined  2012-04-16
Hi grin
I do not know what has happened, but when I came back to my com. later this evening,  everything was suddenly there in Poser formats, where it suppose to be, and it seems work just fine. I have no idea why. But I´ve got the cave!!
Studio Formats still looks strange, but I´ll leave it there for now. It does not seems to make any trouble.
So thanks for all your help!! And next time I get a zip file I`ll do it all by hand, like you Nielv 1
Thanks again grin
All the best
Peter
Profile
Posted: 30 June 2012 01:42 PM   [ Ignore ]   [ # 8 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Hope the Hangover is better also, that would be two win’s in one day.
 Signature
Profile
Posted: 30 June 2012 03:31 PM   [ Ignore ]   [ # 9 ]
New Member
Joined  2012-04-16
Hangover is gone. And I´ll never do it again LOL
All the best
Peter
Profile
