Digital Art Zone
Downloaded Victoria 4 but won’t load ?
Posted: 30 June 2012 08:09 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2012-06-03
Hi Finally discovered that Victoria 4 is the same base model that Magix101 used for his hair product originally, but it won’t upload to the work area ? I just keep getting the message below which I can’t follow….
Thanks smile
Image Attachments
 Signature
“Those curious locks so aptly twin’d,
Whose every hair a soul doth bind.”
Thomas Carew 1595 ~ 1640
Profile
Posted: 30 June 2012 08:23 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Are you using the actual V4 base model ?
http://www.daz3d.com/shop/victoria-4-2-base/
http://www.daz3d.com/shop/victoria-4-2-pro-bundle/
or are you using the V4 morph set for genesis
http://www.daz3d.com/shop/v4-and-m4-shapes-for-genesis/
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 30 June 2012 08:45 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
chohole - 30 June 2012 08:23 AM
Hi weather’s a bit better today grin
The top one, the 4-2 base as the face is definitely the closest to Magix101’s hair models. I’d tried emailng him but no reply, then later discovered he’d used Victoria 4 base so I thought I’d have a go at creating the closest possible likeness myself.
 Signature
Profile
Posted: 30 June 2012 08:54 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi Marcuse smile
Your screen shot shows that you’re in the “Poses” area of the library.
You need to have the Victoria 4 “Figure” loaded in the scene before you can apply a pose to it.
If the V4 model was the one used, then you may also need some of the additional “Morph” packs, such as (Morphs++ for V4) to change the shape of the facial features.
the basic V4 comes with some basic face morphs for speech and expressions.
Profile
Posted: 30 June 2012 09:09 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
It looks like you installed the Powerloader to a DAZ Studio Format content folder—it needs to be installed into the Poser format (Runtime) folder with the Poser version of V4.  To load it, go to “Poser Formats > My Library > Figures > DAZ People” and double-click on Victoria 4.2
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 30 June 2012 09:34 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
fixmypcmike - 30 June 2012 09:09 AM
Bit lost….ohh
Image Attachments
 Signature
Profile
Posted: 30 June 2012 09:37 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
3DAGE - 30 June 2012 08:54 AM
Hi Marcuse smile
Thanks for the tip ! Still can’t remember where everything is and what comes first grin
 Signature
Profile
Posted: 30 June 2012 09:40 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Marcuse - 30 June 2012 09:34 AM
Bit lost….ohh
Your screenshot shows it was installed in the right place.  To load it, go to Content Library tab and look in “Poser Formats > My Library > Figures > DAZ People”.  It will show the .cr2 with a scroll symbol in the upper left to indicate that it has a DAZ script which will run when you load it.
 Signature
Products In Zips
Profile
Posted: 30 June 2012 11:26 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
fixmypcmike - 30 June 2012 09:40 AM
Got there in the end thanks. Having more or less understood how to change facial expressions ok the main problem now, having never done it before, is how to achieve the closest facial resemblance to Magix101’s model from what I think (?) are 3 separate models’ faces of Victoria 4. without having to do everything all over again. The first pic is Magix’s101 the one I’d originally hoped I could use or buy; the second labelled Victoria 4 is what I think is the easiest and closest to the first, and finally the third is what’s appearing in the scene but bears little facial resemblance at all.
Edit: What I meant sorry - did the face in number 2 start out as number 3 ?
All thoughts much appreciated grin
Image Attachments
 Signature
Profile
Posted: 01 July 2012 01:07 AM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2010-06-18
Hi Marcuse…
Yes the character in the second image is the base Victoria 4. She just looks different because of the Hair, Skin Texture and the Lighting, but she is the same as the figure in the third image.
You will need to use the Morphs++ for Victoria 4 in order to change the looks of the base Victoria 4. The base figure only comes with expression morphs and male morphs.
Hope this was helpful… smile
Profile
Posted: 01 July 2012 09:58 AM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
niccipb - 01 July 2012 01:07 AM
Hi Marcuse…
Very helpful indeed thank you !! I’d decided to go ahead anyway but at the back of my mind I was really hoping it wouldn’t all be wasted. Just hope I can manage to reproduce the lady in the first picture as she’s absolutely stunning ! smile
 Signature
Profile
