Digital Art Zone
Noob here. I’m trying to find info on how to add music to DAZ.
Posted: 24 May 2012 08:47 AM   [ Ignore ]
New Member
Joined  2012-04-20
Hey everyone I’m new to DAZ and I’m trying to find info on how to add music to DAZ (sound bite?)  I’ve been watching stuff on YouTube but I can’t find anything on how to add music.
Also I’ve been using animate and I’m having a hard trying to figure out how to zoom out.  I have two figures in frame, but when i start to get them to dance I can only see one or one and half of the other one.  I can never see both.  Could someone tell me what I need to do to be able to see both.
Thanks
Profile
Posted: 24 May 2012 09:15 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI Votero22
under the EDIT menu in Daz Studio 4, you should see an option to ad AUDIO.
You’ll then get a window where you can browse to select an audio file .
To see more of your scene, you can either create a “new camera” then move it back from your figures,
or, select a different viewport layout, for example the “Quad” view, allow you to see four different views,
EG: Front, Left, Camera1, Top.
you can also change any of these views .
hope it helps smile
Profile
Posted: 25 May 2012 06:01 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-04-20
hi 3DAGE,
I found audio file but how do attachet it?  I found song and when I click open it say’s nothing there, but I know it’s there becuase I listen to the song on my computer.  any help would be great..
Profile
Posted: 25 May 2012 08:20 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI smile
Make sure you’re using an audio file format which Daz Studio can play ,. Either .WAV on PC , or .AIFF on Mac
Compressed audio formats like MP3 will not work.
hope it helps
Profile
Posted: 25 May 2012 02:08 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2012-04-20
3DAGE,
I am using MP3.  can you tell me how to covert an MP3 to WAV on my PC?  Is there a program? Thanks for all your help.
Profile
Posted: 25 May 2012 06:22 PM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Try www.downloads.com
it’s a useful source for legitimate Trial / Demo / Free-ware
There should be some MP3 to WAV converters there.
I can’t suggest any specific program, as I make my own music, so, converting MP3’s into WAV, isn’t something I use a separate program for,.. since most music sequencers will export as Wav and / or MP3 if you need it.
Also, bear in mind the possible copyright issues of converting and/or using this audio, if the audio isn’t your original creation.
hope it helps
Profile
Posted: 26 May 2012 08:41 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2012-02-03
votero22 - 25 May 2012 02:08 PM
3DAGE,
I use Free Rip (http://freerip.com/). I usually use it for converting WAV to MP3 (my DAW won’t export MP3 without an expensive plug-in), but it works going the other way, too. It supports a wide variety of audio formats, so it should handle anything you might throw at it.
Profile
Posted: 29 May 2012 06:40 AM   [ Ignore ]   [ # 7 ]
New Member
Joined  2012-04-20
Thank you both I will try.. grin
Profile
Posted: 29 May 2012 08:08 AM   [ Ignore ]   [ # 8 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
STUPID question time: Are you trying to add a lip synced voice or are you trying to add background music?
If you wish to add background music you will need a third party video editing program. Load your Animation into it and add the music as a track behind (lower on the tracks) of sound than your lip synced voices.
The Audio in DS is only for adding speech files to your characters to make them talk.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 29 May 2012 08:42 AM   [ Ignore ]   [ # 9 ]
New Member
Joined  2012-04-20
Jaderail,
I’m trying to add music to my dancing characters.  How would I do that?
Profile
Posted: 29 May 2012 09:44 AM   [ Ignore ]   [ # 10 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi Votero22 smile
Normally,. (even in feature films) the sound and vocals are recorded and added in (post production)
You would use a Video editor Like Adobe Premiere, Adobe After effects, Final Cut, to “Composite” the animation frames, an the audio soundtrack, vocals and effects tracks.
As Jaderail points out,. Audio in DS4 is mainly used for creating Lip-sync animation from a vocal.
However,.. You should be able to add Music, as long as it’s in WAV format. and it should play back with the animation.
Audio will only be exported with the animation is you render to a movie format like AVI, and that usually means either a really Big (uncompressed) file,. or a smaller (lower quality) compressed file.
That’s why the audio is added to the animation in post production, ..to retain the High quality image, and have the ability to edit the Audio if needed.
Hope it helps smile
Profile
Posted: 29 May 2012 09:57 AM   [ Ignore ]   [ # 11 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
votero22 - 29 May 2012 08:42 AM
Jaderail,
What Operating System are you on? Windows or Mac?
Please note: as 3Dage points out you can add the music in DS so it will save with your file but that is not the best way to do it. Keep your Ram free for the animation.
If your Win, the stupid Movie Maker would let you do it. Just Make your animation and save the file. Open Movie Maker load your Animation and then add your soundtrack.
 Signature
Profile
Posted: 29 May 2012 08:22 PM   [ Ignore ]   [ # 12 ]
Member
Rank
Joined  2011-03-31
I can recommend Audacity if your still looking for a free program to convert your sound. It also has all sorts of editing features if you want to tweak your sound to suit your animation.
http://audacity.sourceforge.net/
Profile
Posted: 30 May 2012 09:14 AM   [ Ignore ]   [ # 13 ]
New Member
Joined  2012-04-20
I just want to thank everyone for all the help and input.  I’m sure I’ll be asking more questions…  I’m trying to do a project for my kids and I’m not good with computers. LOL grin
Profile
