Digital Art Zone
No searching by Published Artist ruins sales
Posted: 29 June 2012 01:01 PM   [ Ignore ]
Power Member
RankRankRank
Joined  2011-11-16
This seems like it should be a high priority fix. People haven’t been able to search by PA since the store opened, which makes any PA sale a pita.
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 29 June 2012 02:25 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2005-01-18
I think you’re absolutely right! As a workaround untill it’s fixed you could use this:
http://www.daz3d.com/shop/catalogsearch/result/index/?limit=60&q=nameofartist
instead of nameofartist just fill in the name of the artist you would like to search for. If that are two names, like jack tomalin, put in an underscore like: jack_tomalin
Hope this helps a bit. Oh, and you get 60 products on one page… wink
Love, Jeanne
 Signature
I am what I am, my own special creation
Profile
Posted: 29 June 2012 02:43 PM   [ Ignore ]   [ # 2 ]
Power Member
RankRankRank
Joined  2011-11-16
I get “There are no products matching the selection” same as if I do advanced search (which isn’t very obvious btw.) For anyone trying the advanced search, click on the down arrow next to the search dialog box. It doesn’t work however.
 Signature
Profile
Posted: 29 June 2012 03:20 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2012-04-14
There is an all vendors that has appeared: http://www.daz3d.com/shop/vendors/ but I think they’re still working on it because it doesn’t seem to be populated.
Profile
Posted: 29 June 2012 03:30 PM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
If you know the PA in question correct name just enter it into the search box, top right of the store.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 29 June 2012 04:15 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2005-01-18
Gedd - 29 June 2012 02:43 PM
That’s odd. You copied the code and pasted it in the adress bar above the page?
If I want to search for Mab for instance, I copy the code, paste it in the adress bar on top of the page ( I use IE9) put in mab instead of nameofartist and it searches for Mab’s store… and finds it smile
http://www.daz3d.com/shop/catalogsearch/result/index/?limit=60&q=mab
But of course Chohole is right and you can enter the name of the artist in the search field top right of the page. What I described is just what I do also if I’m not on the site already….. and it gives me 60 products a page immediately raspberry
Love, Jeanne
 Signature
Profile
Posted: 29 June 2012 04:21 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2008-02-14
If you put the vendor’s name in the store search (not the forum search) you will get a listing of their products.  Most vendors used the link that search provided for their signature lines until a permanent solution gets coded into the website.
for example:
http://www.daz3d.com/shop/catalogsearch/result/?q=Jack+tomalin
http://www.daz3d.com/shop/catalogsearch/result/?q=stonemason*
http://www.daz3d.com/shop/catalogsearch/result/?q=firstbastion
 Signature
PUBLISHED ARTIST
First Bastion’s Environments here at Daz
Gallery
Profile
Posted: 29 June 2012 07:15 PM   [ Ignore ]   [ # 7 ]
New Member
Joined  2006-01-02
Changing the stores ‘sort by’ filter to ‘release date’ from the dropdown list has changed the vendors information into to pages of nothing with the ‘There are no products matching the selection.’ message every time i’ve tried to use it.  If you have the store set to show results by release date then that could be the problem.
Profile
Posted: 29 June 2012 10:33 PM   [ Ignore ]   [ # 8 ]
Power Member
RankRankRank
Joined  2011-11-16
I get the ‘There are no products matching the selection’ randomly and more often then not. I am using Firefox, but I don’t intend on using IE. And yes, I copied and pasted text, I put name in search bar… ‘Dreamlight’ ... one word, hard to mess up…
 Signature
Profile
Posted: 29 June 2012 10:35 PM   [ Ignore ]   [ # 9 ]
Power Member
RankRankRank
Joined  2011-11-16
FirstBastion - 29 June 2012 04:21 PM
If you put the vendor’s name in the store search (not the forum search) you will get a listing of their products…
Um, no… ‘you’ will get a listing of their products. Don’t assume because it works for you it works for others. Don’t mean to sound rude btw, I do appreciate people taking the time to reply.
 Signature
Profile
Posted: 29 June 2012 11:00 PM   [ Ignore ]   [ # 10 ]
New Member
Joined  2006-01-02
I am using Firefox 14.0 and can bring up the Dreamlight listings.  Which version of Firefox are you on?
Profile
Posted: 30 June 2012 03:48 AM   [ Ignore ]   [ # 11 ]
Member
Avatar
Rank
Joined  2006-04-05
Gedd - 29 June 2012 10:33 PM
Gedd, using IE will make no difference, it still breaks.
The method described by chohole works for me UNLESS I try to amend the search parameters e.g. change to release date. From that moment on the search is broken and will not search for ANYTHING in the store - returns blanks. I log out, log back in and it works again but only if I don’t try and change anything. I am using IE so I don’t think this is browser specific but a site glitch.
 Signature
My DevArt Gallery
Profile
Posted: 30 June 2012 04:25 AM   [ Ignore ]   [ # 12 ]
Power Member
RankRankRank
Joined  2011-11-16
Haruchai - 30 June 2012 03:48 AM
... using IE will make no difference, it still breaks… I am using IE so I don’t think this is browser specific but a site glitch.
Yes, that is pretty much the same conclusion I came to. Logging out and back in does seem to fix it and changing parameters in search or even doing repeated searches (at least some of the time) seems to break it. Basically, it needs to go through a full test cycle to see exactly how/when it breaks to identify/fix.
 Signature
Profile
Posted: 30 June 2012 04:56 AM   [ Ignore ]   [ # 13 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Daz does know there are still some glitches in the search, and are working to fix them.
 Signature
Profile
Posted: 30 June 2012 05:06 AM   [ Ignore ]   [ # 14 ]
Member
Avatar
Rank
Joined  2006-04-05
chohole - 30 June 2012 04:56 AM
I guessed as much. The new vendor profiles should help a great deal when they get populated.
Really trying not to be too negative and try to post symtoms I’ve not seen mentioned or clarify those that are different for me. I can only imagine the list of things on DAZ’s ToDo list, sometimes the frustration takes over though. Will try and bite my lip a bit more and wait.
 Signature
My DevArt Gallery
Profile
Posted: 01 July 2012 04:27 PM   [ Ignore ]   [ # 15 ]
Addict
Avatar
RankRankRankRank
Joined  2007-11-06
...pretty much any time i try to filter store results by date I get this:
 Signature
...forsaken daughter is watching over you…
Profile
