Digital Art Zone
1 of 2
1
Frustrated with Gen 4 ‘Fixes’ considering switching to Genesis
Posted: 27 June 2012 08:10 AM   [ Ignore ]
Member
Rank
Joined  2010-12-22
Hi everyone.
I have been using Gen 4 figures for years and have a nice library built up. Recently I have been trying out some of the ‘fixes’ for the common problems with Gen 4, ie: thigh bends, arm bends, etc. I have bought and tried several products, but none of them have really wowed me. Some of them work, but are really fiddly and easily corrupted. Others claim to be quick, easy fixes but don’t really work all that well.
One of the main problems seems to be that the fixes rarely work well with any body morphs, including common ones like th Elite series. I have a really hard time getting bodies that aren’t standard issue work well with these fixes. For example, thinner characters and thicker characters…both seem to break all of the ‘fix’ products I have tried. Seems kind of pointless to have a ‘fix’ that only works with a stock Gen 4 figure. What if I want to use it with V4 Slyph, for example? I tend to end up with really messed up figures.
I’m also really reluctant to switch to Genesis because I don’t want to lose my existing library. I have spent years investing in Gen 4, and can’t afford to replicate that investment anytime soon. I know some things can be converted, but that seems like a difficult and unreliable process. Maybe I am just not very good at using the different fix products I have tried. Maybe I just need to invest more time in getting better at using them.
So, now that Genesis has been out for awhile, would people suggest that someone with my concerns switch over? The current sale is really tempting. I know people still have strong opinions on this, but my issues are fairly specific and I would appreciate any feedback.
Thanks!
Profile
Posted: 27 June 2012 08:20 AM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2011-01-22
The only problem with switching to Genesis is that your Gen4 characters will feel second rate and obsolete after at most a week :)
Profile
Posted: 27 June 2012 08:27 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2008-06-25
I’d say it’s worth moving over to Genesis.
All the Gen4 textures work well on Genesis by default (M4 ones need UV switching, but it’s one click in the surfaces tab).
Looking at the Studio 4.5 RC threads, it appears the autofit troubles etc are being actively remedied; plus, there’s always manual workarounds (like - if that’s all about shoes - parenting them instead of conforming; and then, Hexagon is free as of now, and this is a capable modeler that lets you fix many problems through the Studio bridge). Those workarounds may take quite a lot of hassle indeed as of right now, but the overall joint quality of weightmapped figures is much better, in my experience.
And having the M4 and V4 shapes for Genesis lets you have all your V4/M4 character morphs using just the transfer utility (the standalone GenX utility is said to work even better, but I like the built-in results).
So I’d say it’s worth it, for a Gen4 user.
 Signature
do your research before blaming 3Delight for shortcomings of your renders
dA gallery link in profile along with anything else you may need to know about me
Profile
Posted: 27 June 2012 08:44 AM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2010-12-22
Thank you for the replies. So would you say that the following two issues are greatly improved with Genesis:
1) Gen 4 ‘problem’ areas such as the arm bends, thigh bends, etc. Especially with non-stock character figures, ie: if I use a V4 Elite Slyph style character with V5, it will handle those bends as well as the stock V5. (This is the big one)
2) Varied character figures, ie: V5 with varied leg lengths, hips, breast sizes, etc. (Also important since I felt like I had to invest in tons of extra packages for Gen 4 to get bodies that really captured the full range of possibilities)
Thanks.
Profile
Posted: 27 June 2012 09:21 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2008-06-25
In my experience, all the Genesis shapes I dialled in, including Gorilla and my own custom sculpted morphs, bent quite fine. Even mixed to atrocious proportions. But I may not be that creative with bending, of course. Normal poses look very good =) I also have to add that while I always dialled some Aiko4 “taper fingers” into V4 to make her hands look less lumberjack-y, I didn’t need it with V4 Genesis shape.
Do you have DS4 installed? This is all it takes, and you could test Genesis yourself - there’s several body shapes included free which are quite varied, and can get crazy if mixed randomly.
 Signature
Profile
Posted: 27 June 2012 09:47 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2004-11-12
MadisonXF - 27 June 2012 08:44 AM
Thanks.
1) IMVHO Genesis bends much better than V4, including V4WM.  I’m sure this is not only due to the new weight mapping system, but also due to the much better topology of Genesis for human figures (instead of throwing additional polys at it, they designed the polys to mimic the human form). Dialing morphs has very little, if any effect on bending. I would suggest getting the Evolution morph sets as well as V5, you will have almost infinite possibilities and variety. If there are certain V4 characters that you would really like to use with Genesis, then getting the V4 morph (note - this is only the base V4 shape, no morphs, but you can use any of the other Genesis morphs in combination with it), and GENX (or using the transfer utility) to easily recreate your favorite V4 characters with Genesis.
2) Again, this is just my opinion, but there really is no comparison between V4 and Genesis for creation of varied and scaled figures. Genesis really is that much better.  I have all the Evolution morphs, V5, V4, G4, V3, A3, and some of the custom characters, and I don’t regret buying any of it because of the amazing possibilities and infinite combinations you get with Genesis.
if you haven’t already done so, you should download DS4 and play with the default genesis figure a bit, then maybe get one of the starter packs that are on sale with a morph set you are interested in, the Genesis Starter Bundle looks like a good choice (http://www.daz3d.com/shop/genesis-starter-bundle/). I think once you see first hand how easy it is to use and morph Genesis, you’ll really like the results.
 Signature
My Rendo Gallery
Profile
Posted: 27 June 2012 11:21 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2010-12-07
You could try V4WM, you have to convert clothes but from what Ive read its not too complicated and you can still use all your V4 stuff with Poser.
Profile
Posted: 27 June 2012 11:55 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
MadisonXF - 27 June 2012 08:10 AM
Hi everyone.
My perspective is that as a Studio user Genesis has massively enhanced the value of my library, not put it at risk.
I can now use any Gen3 or 4 item of clothing on any character. There’s the odd auto-fit foul-up, but it is only the odd one, and a lot better than the old-days of unsupported morphs rendering clothing useless for anything but the most basic of morphs. Hair remains fully usable, Gen 4 character textures can be used without issue, GenX lets me use Gen3 and 4 character morphs in Genesis without issue. The only things I can’t swap over are Gen3 skins (don’t really have enough to justify buying TC2 and it’s easy enough to find a compatible Gen 4 skin) and characters for the Gen 3 kids, and I can still use those in their existing format.
That last point bears repeating, I can still use every Gen 3 and Gen 4 item I ever bought, the risk to your existing library is zero, the only question is the return on investment from buying into Genesis, and the price to do that is currently pretty minimal.
Profile
Posted: 27 June 2012 01:53 PM   [ Ignore ]   [ # 8 ]
New Member
Joined  2011-11-14
This is the perspective of a total neophyte to this world of Daz.  Maybe its relevant and maybe its not but here goes.
A good friend of mine tried to get me hooked on this hobby when I was only able to get the base version of Daz Studio.  I tried it and found it too difficult to figure out.  Then, when the “big giveaway” happened, I tried it again.  This time it took.  I had no content library to start with and began just using what came with the program and the content I was able to get with a voucher in my account for one of the starter bundles.
At first I thought I was limited to just “Genesis stuff” but then the friend I mentioned previously stepped in to assist me again and I learned that I could use just about anything that was “V4 and M4 stuff”.  Then, I joined the Platinum Club and for what I consider a very reasonable outlay, I have begun to accumulate a library of assets from all over the range of what Daz and the Published Artists have done.  Up to this point, it all seems to work and work very well with Genesis.
I guess the point of my somewhat rambling “2 cents” here is that Genesis is fantastic in my opinion.  After listening to my friend’s reminiscences of how she had what seems to be such a higher learning curve when she started this with the generation 3 and generation 4 figures, I am so very thankful that it has been made easier for me with the Genesis figures.
So, yeah, Genesis is absolutely excellent and everything seems to work just fine with it.  I would say go for it.
Profile
Posted: 27 June 2012 02:49 PM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2010-12-22
Wow thanks for all the great replies. I think I’m sold.
I will probably start with some of the bundles, since they are on sale. Aside from the previously mentioned Genesis Starter Bundle, do you guys have any recommendations on key Genesis products? I will definetly grab V5 and M5. I’m more interested in modern styles at the moment, and will probably save the fantasy / sci-fi items for later. My main concern right now is basic character anatomy / morhps / etc. for Genesis.
One concern I have is that some items seem to be restricted to certain bundles. I noticed that something basic like genitals is only available in the Pro bundles. Why is that? Seems weird that you are forced to buy a bundle to get an item, instead of just buying that particular item. This sort of thing makes me a litte leary of the various bundle options. I don’t want to get hosed buying the ‘wrong’ bundle and then finding that some simple item is only available in a different bundle.
Profile
Posted: 27 June 2012 04:05 PM   [ Ignore ]   [ # 10 ]
Member
Avatar
Rank
Joined  2007-09-11
Get the GenX plugin and the V4 and M4 morphs for Genesis. You’ll be able to transfer your favorite Mil 4 morphs to Genesis. More bang for your buck!
Profile
Posted: 27 June 2012 05:10 PM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Daikatana - 27 June 2012 01:53 PM
I just wanted to highlight and add to this one part for any new user out there. Now you may run into some unhappy people who are upset about something or other they feel Daz has done and they may claim otherwise, but hands down for the novice 3D artist just coming into this hobby, hands down the Platinum Club is the best investment one could make. Besides hundreds of items at a regular price of $1.99 and a dozen or more brand new never before released items every month also for $1.99 you also get a monthly voucher for $6 and 30% additional 30% discount on new published artist products. Also periodically they will also give special limited time deals such as a new figure or a new program (Like Bryce for example) at a riddiculously low price. Additionally PC members often get advanced access to exciting new products before non members. If that weren’t enough once a year for a whole month they hold a PC Member Appraciation promotion for the whole month with all sorst of fantastic deals and bonuses. A sharp newcomer can easily more then pay off a annual membership with the savings they can get and there is no better way a newcomer can build up an impressive library for the least amount of money then by being a PC member and taking advantage of all the deals it provides you.
I know first hand, I was a PC member for nearly 10 years straight and would still be one now if the economy hadn’t tanked and put me in the situation I’m in forcing me to cut back on non essentials (which yes, unfortunately does include 3D content). Although it’s not too bad with a content collection of several thousand different items to work with in my library I got enough already to keep me busy for a lifetime.
Profile
Posted: 27 June 2012 07:10 PM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2006-10-01
I have to agree with what has been said.
1) Genesis bends much better. I used to postwork the bendings. Not anymore. Its a huge improvement.
There is some kind of automatic rigging adjustment for characters. This means V5 or M5 are not just morphs for Genesis, they have their own rigging that adjusts “behind the scenes”.
Transferred Gen 4 characters will also bend better.
2) I have GenX, I could transfer Gen 4 characters and morphs to Genesis if I wanted to, but to be honest, the morph mixing possibilities are now so high, I don’t bother with Gen 4 morphs anymore.
Your previous content will actually be a lot more useful now. Once you start using Genesis you’ll start to feel things were much more limited with Gen 4. I can use and mix clothes, hair and textures of any character with any character I want without worrying about morphs included. This has opened a lot of possibilities for me and has made useful a lot of content I had buried.
I’d also recommend joining the Platinum Club before picking stuff. It has saved me a huge amount of money.
I’d concentrate on morphs, you can stick with textures, clothes and hair from Gen 4 for now.
 Signature
My works with DAZ Studio and stuff.
Simplified guide to Genesis content creation.
DSA Bulletin Board. Promote your products here.
Profile
Posted: 27 June 2012 07:49 PM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2012-02-07
Greetings,
+1 to LordHardDriven; I joined the PC before I made a single actual-money purchase from DAZ (i.e. it was, essentially, my first), because I realized after browsing for a bit that it was VASTLY financially superior to be a PC member.  This is still true, and absolutely nothing has changed my mind on that.
I think that DAZ should reinstate the ‘If you were a PC member, this would be your price’ segment of their item pages (for non-PC members, of course) as that’s got to be GOLD for increasing memberships.
The folks who are complaining about the PC are Poser-only, have been in it for MANY years, and have already bought nearly all of the $1.99 items over those years.  (And are often ignoring the locations and props that get released, which are platform independent.)  For anybody using DAZ Studio, or is new to the Platinum Club, it’s an amazing deal.  And one I’m confident will get better as DAZ makes changes to make up for some of what the old-timers feel they’ve lost.
IMO, don’t start buying stuff here without joining the Platinum Club.  It’ll pay for itself VERY quickly.
— Morgan
 Signature
Want to be notified when items on your wishlist get discounted?  Want to sort and view your wishlist better, or to see ALL the current discounts? http://3dwishlist.com/demo
Want the old forums to work, or tabs gone on details pages?  How about ‘Show Specials’ back on the wishlist?  On Firefox (with Greasemonkey) or Chrome: http://userscripts.org/scripts/show/133738
Profile
Posted: 28 June 2012 12:11 AM   [ Ignore ]   [ # 14 ]
Member
Rank
Joined  2003-10-09
Before you start pouring money and time into the Genesis hole you might want to study how soft bodies act, accept the loss on the “fix” morphs, and learn to use the morph tools to actually fix the mesh overlaps to realistically portray soft tissue compression.
Profile
Posted: 28 June 2012 12:43 AM   [ Ignore ]   [ # 15 ]
Power Member
Avatar
RankRankRank
Joined  2007-11-30
I’m also going to move over to Genesis, but only when they have a stable release of DAZ Studio (General Release). I’m not going to be a debugger for DAZ3D.
 Signature
Still not bald.
Profile
1 of 2
1
