Digital Art Zone
Using a OBJ Morph
Posted: 26 June 2012 05:25 PM   [ Ignore ]
New Member
Joined  2010-01-21
I managed to find the Luke Skywalker for M4 morph I was looking for, but I cannot get it to work under Daz Studio 4.
The readme says
“unzip folder to morhps folder or anywhere.load m4 click on head goto objects click on load morph target find luke-head-morph done.the dial needs tobe turned to 1000 to show morph.the eyes may need tobe adjusted,get the m4 unhide dials script to get eyes right.”
I’ve loaded M4 and all his morphs via the PowerLoader. I’ve select M4’s head, gone to
edit ->figure->Morphloader Pro
and chosen the unzipped .obj file, clicked ok and Daz3D says
“Created luke-head-morph successfully”
However no new morph seems to appear, and the figure remains unchanged. I’ve even tried Morphloader Advanced and the edit->object->Morphloader Pro as well to no avail
Umm… help?
Profile
Posted: 27 June 2012 09:25 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I have a suspicion that you are trying to use a morph that was spawned in poser, and as such will probably only be usable in Poser.
Do you know the name of the person who made the morph, by any chance, so I can confirm this is the case.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge for June        June Freebie Challenge
11915 was the number
Profile
Posted: 27 June 2012 09:52 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2010-01-21
I believe it was someone called WERTS
Profile
Posted: 27 June 2012 10:26 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Then yes it is a Poser only morph, spawned from Poser and only usable in Poser, I am afraid.
Werts morphs are actually no longer available.
 Signature
Profile
Posted: 27 June 2012 01:34 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2012-04-07
Edited by me.
Thank you Chohole, yes those are the inj poses I was remembering as being available.
 Signature
A couple of tutorial re-ups for those wanting them.
Making skins [basic start]
Unpacking Zip Folders [i.e. how to deal with a gazillion folders if not using DIM]
Profile
Posted: 27 June 2012 01:49 PM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Yes and those ones by Marieah are the only ones that are now legally available, because the others were all withdrawn from distribution.
 Signature
Profile
Posted: 30 August 2012 08:26 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2009-04-24
I am having the same problem with morphloader in daz 4,except that I am trying to load a head morph i created with faceshop 6ez. It tells me it is successfully loaded but it makes no difference to the model intended’s head.
Profile
