How to clear/remove all "currently used" parameter changes to object and its' children
Wondering if this is possible;
Basically, I've adjusted limbs, hands, fingers, and want to "zero out" or remove all the changes I've made to them without totally resetting the figure to a predefined pose. If I could reset [everything below shoulder] for example that would be the best.
Is there a way to do this?
Thank you so very much.
  • Tramp GraphicsTramp Graphics Posts: 2,091
    Actually, it's pretty easy. Simply select the specific node(s) (if necessary, one at a time) and then go to the little box in the upper left hand corner of the Parameters tab, go to Zero> Zero Selected Items Pose (or Shape, depending upon what you want to zero out).
  • Richard HaseltineRichard Haseltine Posts: 42,056
    The zero commands are also in the Edit>Figure menu in recent builds of DS, if you have allowed the menus or layout to refresh.
