Digital Art Zone
Increase/Decrease fidelity-Carrara7
Posted: 25 June 2012 11:09 PM   [ Ignore ]
Member
Rank
Joined  2012-03-03
Is it possible to increase/decrease the fidelity without using the +/- keys? I am currently using a laptop that does not have a separate number pad. The basic +/- keys have no affect in the program.
Thanks!
Profile
Posted: 26 June 2012 02:28 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi VolcanicMink
Welcome smile
Have you tried hitting the “Num Lock” key.
That should enable the laptop to use the numbers and +/-
There are also external numeric pads you can buy for laptops, ..(usually wireless)
if that’s not an option,. then it looks like your stuck with using the mouse/ touch-pad on your laptop.
Hope it helps
Profile
Posted: 30 June 2012 09:48 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2012-03-03
Thank you. My 10-key died several months ago and I’ve not yet replaced it. Is there actually a way to modify fidelity with the touchpad?
Profile
Posted: 30 June 2012 10:06 PM   [ Ignore ]   [ # 3 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
I do not use Carrara so this is just a shot in the dark.
Keyboard Shortcuts, assign that funtion/s to what you want. I’m just trying to help. This might be the dumbest thing I’ve ever said…
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 01 July 2012 12:34 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2006-01-21
I presume this is when you drag a basic object from the menu bar to the vertex editor?
If so there is an option on the right hand side to set the segmentation level. Type in there and press enter.
Another option is to insert from the ‘Construct’ menu bar. This gives you precise options in a submenu and puts the object at the zero point automatically. Very useful.
Image Attachments
 Signature
http://roguepilot.deviantart.com/
http://www.renderosity.com/mod/gallery/browse.php?username=RoguePilot
http://www.ShareCG.com/pf/full_uploads.php?pf_user_name=RoguePilot
Profile
