Browsing to file location using script
Richard HaseltineRichard Haseltine Posts: 41,960
Is it possible to perform the equivalent of the Content Library's Browse to File Location, opening an OS file window, via script? I have found a browseToAsset(DzAssetPtr) function in the Content Library pane object, but I can't see how to get an asset pointer from a file (ideally direct from a string with the relative path name, or the absolute path name obtained from DzContentMgr, though using a DzFile or FileInfo would be fine). As I am intending to use this, the Content Library would definitely not be showing the asset I wanted to browse to though I think it might be possible to switch to showing the asset in question - but the function also seems to need input other than a straight string or DzFile - and then go back to the original location.
  • rbtwhizrbtwhiz Posts: 1,372
    edited November 2015
    The context is different (i.e. single file vs multiple files) and this simplifies dealing with database records, but here is a DAZ Script that roughly does what the "Browse to file location..." action in the Content Library context menu does:
    var oPaneMgr = MainWindow.getPaneMgr();
    var oPane = oPaneMgr.findPane("DzContentLibraryPane");
    if( oPane ){
     var aAssets = oPane.getSelectedAssets();
     var sAbsFilePath;
     var oAsset, oFileInfo;
     for( var i = 0; i < aAssets.length; i += 1 ){
      oAsset = aAssets[ i ];
      sAbsFilePath = oAsset.getAsLocalFile();
      if( App.version64 >= 1125921381810178 ){//4.5.2.2
       App.showInNativeBrowser( sAbsFilePath );
      } else {
       oFileInfo = new DzFileInfo( sAbsFilePath );
       App.showURL( String("file:///%1").arg( oFileInfo.path() ) );
    -Rob
  • Richard HaseltineRichard Haseltine Posts: 41,960
    Ah, thank you - I thought there should be something in App but I wasn't finding it. That's much simpler than going through the content pane (I will be starting with the relative path available, so I just need to turn it absolute and use the show* function). Thanks Rob.
  • When I use this code I get this error :
    Script Error: Line 8
    TypeError: Result of expression 'oAsset.getAsLocalFile' [undefined] is not a function.
    Stack Trace: ()@:8
  • That's useful - the conversion from the old forum has stripped out the array index [ i ] as well as the carriage returns. The script should be:
    if( oPane ){
    	var sAbsFilePath;
    		else {
  • Ahh thanks !
