Digital Art Zone
1 of 2
1
need an old oil tower
Posted: 24 June 2012 06:43 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Something from the oil boom days ... to match the 1930’s truck and themes. Any ideas?
 Signature
Aidana WillowRaven
http://WillowRaven.weebly.com
I ask for so little. Just fear me, love me, do as I say and I will be your slave.
Profile
Posted: 24 June 2012 09:31 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2006-08-31
These sorts of thing? (not a model, just pictures…)
http://www.bombago.com/082505/~max0114.jpg
http://content.lib.washington.edu/cdm4/item_viewer.php?CISOROOT=/ftm&CISOPTR=734
 Signature
Previous post count: 2678 Downloads Hightide Mark: 1708
Profile
Posted: 24 June 2012 10:26 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Exactly. :D Do you think this is something I need to add to my model request thread?
 Signature
Aidana WillowRaven
Profile
Posted: 25 June 2012 03:38 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
More people might recognise what you want if you called it an oil derrick.
Have you considered putting one together from cube primitives? It’s essentially just a set of beams of consistent size but varying length, all tacked together. Simplest way to assemble it would be to construct one side on the flat, then merge 4 copies together and bring them together in the pyramid form.
Profile
Posted: 25 June 2012 05:28 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
http://www.sharecg.com/v/42815/View/5/3D-Model/Oil-Derrick-Prop
Maybe try with this one:
http://www.sharecg.com/v/48174/View/11/Poser/Simple-Scaffold-V1.0
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 25 June 2012 07:22 AM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
How close are they to the camera?  If they are in the distance then you can easily use primitives to construct one, save it as a scene, and then merge multiple in if you’re looking for many.
If they are up close, and you need lots of detail, you need to decide which type you want.  The wood types were constructed differently from the metal, and you need to decide if they are the temporary types, or the more permanent types.  The area of the country may also make a difference.  Those built in the more northern regions were a bit different than those in the south.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 25 June 2012 08:38 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
DWG - 25 June 2012 03:38 AM
I am nooo modeler ...lol. big surprise
 Signature
Aidana WillowRaven
Profile
Posted: 25 June 2012 08:40 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Kerya - 25 June 2012 05:28 AM
The first is too primitive, the second too straight ... lol. Thanks, though.
 Signature
Aidana WillowRaven
Profile
Posted: 25 June 2012 08:52 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Kendall Sears - 25 June 2012 07:22 AM
This book has it about mid-way. Close enough to see is the period or style is wrong, but not so close as to see what type of wood it is. However, this is series, so I always shoot for good models that are diverse enough for close shots f need be.
Kendall
I need the type common in Texas during the depression era, at the very beginning of the oil boom days. Does that help?
 Signature
Aidana WillowRaven
Profile
Posted: 25 June 2012 09:32 AM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
AidanaWillowRaven - 25 June 2012 08:52 AM
Kendall
OK.  For the distant wells, you can get away with primitives textured with transmaps. (EDIT:  Use a Cone Primitive with 4 sides to get the derrick shape)  Very low poly and easy to work with.  For more visible items, but not highly detailed, you can create either 3 inch x 3 inch, and 4 inch x 4 inch primative cubes and then scale and translate them to the correct places to create the derrick.  Look for images of the “Lucas Gusher” for an example of open derrick construction from that period of time.  It really isn’t that hard.
Kendall
 Signature
Profile
Posted: 25 June 2012 09:45 AM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2008-07-16
The problem with a 1930s oil derrick is that the tower part is fairly simple, and any close up shots would really only show the legs. I’m not sure just the tower will sell the impression of a tower. The derrick should include drilling equipment and perhaps a base deck. Otherwise you could get away with any simple metal or wood frame tower like the ones in the pictures.
BTW- One more annoyance with the new forums: Adding more than one image/attachment sucks!!
Image Attachments
 Signature
VISIT MY ShareCG FREEBIE GALLERY
Profile
Posted: 25 June 2012 10:55 AM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Since I think we’ve pretty much established that a good 3D derrick prop is not currently available for the time period I need, I think I will move this conversation to my “model and product requests” thread: http://www.daz3d.com/forums/viewthread/162/
I know ya say it’s not that hard to build, but I don’t understand blender, nor have the time to learn it, I haven’t had the time to learn my Hexagon software, and I am constantly fighting publishing deadlines ... lol.
Hopefully if I put in my product request thread somebody will pick up the project.
Thanks, guys :D
 Signature
Aidana WillowRaven
Profile
Posted: 25 June 2012 11:52 AM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2008-07-16
When do you need this by?
 Signature
Profile
Posted: 25 June 2012 12:02 PM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
lordvicore - 25 June 2012 11:52 AM
Maybe in two weeks, three on the outside? I posted a request in my model request thread, above. If there are any modelers here that are always on the look-out for unique model practice ... I welcome all. :D
 Signature
Aidana WillowRaven
Profile
Posted: 25 June 2012 02:53 PM   [ Ignore ]   [ # 14 ]
Active Member
Avatar
RankRank
Joined  2008-07-16
I started an oil derrick, it’s just a frame now… I’ll see how much progress I can make and if it makes sense… Reference pictures are hard to come by on the internet… most are very small.
Here is a quick KT render…
Image Attachments
 Signature
Profile
Posted: 25 June 2012 02:59 PM   [ Ignore ]   [ # 15 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
lordvicore - 25 June 2012 02:53 PM
Cool! Would you mind terrible re-posting this in the “model request” thread above? I am trying to keep all of he things I request in one thread.
 Signature
Aidana WillowRaven
Profile
1 of 2
1
