I have a TON of DM products that ended up as Daz Originals. Now these products are not showing in my purchase history at all! Products in my itemized order history are a mess! With 2,000 + purchases, I am seeing very little of my items in my itemized order history. While you might think the changes are good, for someone with a huge order history it is a NIGHTMARE!
Plus it used to be if you had already purchased something it would show when you tried to add it to your cart… what happened to that? One of the most important features you had! Also your download settings…. I now get Mac/DS and PC!!! I only want files for PC! And there is no way to filter these out as before. This is really an awful transition and it seems that it should be getting repaired faster.
Not being able to locate purchases upsets me, and also there is a real disconnect with any searching for your purchases.
It makes me afraid to even do new purchases at all. This is too difficult to navigate, or verify errors. Plus it would really help if you did the ORDER Numbers by the most recent, and then listed products alphabetical separately. As it stands now there is way too much confusion. And if I spend something close to $5,000.00 here, I do expect a better system of tracking my orders.
Itemised Order History is indeed alphabetical, apart from the first set ot items which have not alpahabetical characters as the first character of the item name.
“My Orders” show all your previous orders, and is listed by date, newest first.
I promise I will go look at the “My Orders” section right now. I might be able to find some of my purchases that way. What is
hard is the cross over Daz Original stuff… we all know the MM feeding frenzy, and I am no exception to it. But with all the orders I have, and the names being slightly changed, it is hard to find a lot of older things. Plus I have a new puter, and want to safeguard my RT’s as I find Win 7 likes to lose things too!!!
Thank you Both, I find personally if a site is too hard to navigate, people leave, I am really close.
OK, that does show them numerical by date, which is a relief, but there are no longer live links to the products? That is really inconvenient. Often it is hard to remember what is what, especially since many are now gone from the MP here.
I think the reset should be on these purchases in the “My Orders” section! Let’s call it “Reset this Order”. That way you could reset each numerical oder and download easier!
At least I found several of my “Lost” purchases! But they are not showing as named in the orders, in the itemized order history!!! Especially V3 items. Either the name is different or they no longer exist, but I bought them and they should be they permanently for my access.
Nope, I haven’t tried the Rendo variant myself, I have bought very little from there. But it should work OK. And history’s reset function isn’t, IIRC, functional yet, as the creator said it needs some tweaks and whatnot.
Yes, the History Reset feature needs some work so that it among others will verify that the files have been reset correctly. That may take some time however, so I’ve added a simple reset feature in the latest version (0.530)
Seems to work allright but if the server goes nuts during the process (in that case you should get an error message) you must sort out for yourself which files have been reset and which not. Or you can reset everything again and see if it works this time. Help file has been updated to cover all new features.
I’ve also added automatic update check though that was in the previous version (0.529) which was uploaded yesterday. If you want to update, please download 0.529 from here:
