If it’s for Gen4, chances are that the model itself is compatible, but unless there are specific DS materials included, you might have to make adjustments to the materials yourself. RDNA *does* test in DS, so if there was any specific compatibility issue in the basics, it would say so in the product description.
Checking it, it does say that there are basic material settings for “easy import into other software”, I would think that could be read as “to use as starting point in DS”. Just don’t expect to be able to load the P9 materials in DS because those will definitely not work, for obvious reasons.
